Bearing material in oil
ksbowman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Topic: Bearing material in oil
    Posted: 19 Jul 2017 at 5:24pm
I am 67 yrs. old and have been working on equipment and vehicles since I was 8-10 yrs. old starting with my father. I have never had a problem with rod or main journal bearings going out although I've overhauled a lot of motors replacing them in the process. Common knowledge tells me if a motor is having bearing problems you should be able to drop the oil and there should be some shavings or bearing residue in the oil or the bottom of the pan. Is my thinking correct? Thanks
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2017 at 5:28pm
Yes but sometimes it is impossible to see. We started oil sampling in the 1970's. Needs to be done every time you change oil.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2017 at 5:52pm
Depends on how large the material is. When doing an oil sample there may be traces amounts of the metal in the oil. That's normal, within bounds. Shavings or chips on the other hand....
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2017 at 7:50pm
Why do you believe you have a bearing problem ?????????
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2017 at 8:28pm
Cut the filter apart there will be filings for sure in it if it has bearings issues
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2017 at 9:35pm
Steve, I don't think so. I had an issue last winter with my 170 diesel. When I had it warming up (it was below zero out) I noticed I had a leak at the valve cover and it was puffing smoke/vapor and then I had a high pitched squeal start so I shut it off. I have a 180 and a 190 so I just used them and never messed with the 170 (170 has always been my go to Tractor). A couple weeks ago I fixed the valve cover gasket and loosened the fan belt and the squeal wasn't there when I started it up (started easy). The engine seemed noisy. It has always been noisier than the 180 D. So I thought about the squeal last winter and thought " I hope it didn't spin a bearing". Today I drained the oil and when I drained it I stretched a white T shirt over the 5 gallon bucket so I could see if anything ill regular came out and it was clear of any shavings or color. Checked the plug and all that was in it was a dead fly and 1 very small piece of metal. Pretty sure my pessimistic attitude is creating a problem where there isn't any. To be on the safe side I wanted to look for shavings in the oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2017 at 9:37pm
Gary, I'll do that tomorrow. I even stuck my finger up the drain hole onto the bottom of the pan, but didn't get anything either.
BigBadAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigBadAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2017 at 8:35am
You won't be able to visually see the wear material unless there's very large pieces.  The bulk of the wear material will be from 0-10µm (microns) and not visible.  The only way to know is to perform an oil analysis which will provide all of your wear metals in ppm as well as a lot of other information.  I own an oil analysis laboratory and willing to run analysis for any of the AC Forum members at cost.  I got into this business because of my love for working with equipment.  Long time AC guy from a family dairy farm in MI will all AC's
https://apexoillab.com/
(616) 328-6672 and ask for Jason
