6080 STERRING TROUBLE.
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Topic: 6080 STERRING TROUBLE.
    Posted: 17 Jul 2017 at 8:52pm
on my 6080 when I turn to the left it turns the way it should but when I turn to the right I have to turn the steering wheel about twice as many times to turn the wheels, what do you think the trouble is? Thanks Tom.
Edited by ctbowles58 - 17 Jul 2017 at 8:54pm
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 10:00pm
My first thought would be nut on end of cylinder is loose.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 5:02am
MACK, I will check that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 10:14am
I checked the cyl. all seems ok.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 11:42am
Mine does that occasionally. Usually when I'm brush hogging and when it's good and warm. If I turn the wheel left the tires wornt turn at all. If you then turn to the right it will work again. Doesn't do it very often though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 3:30pm
Mine is getting worse, I don't know what it is, but I am thinking its in the PS. pump, maybe a bad "O-RING".
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 9:40pm
I'm pretty sure Mack was talking about the nut inside the steering cylinder, holds the piston to the ram.  It gets loose and there is a lot of play in the system.  Don't know how to check it other than disassemble the cylinder.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 9:50pm
Gut says steering control valve needs rebuilt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 10:32pm
I have similar thing going on to. But I only notice it on the road. Going down road I say it's drifting to the left. But I don't think it's so much drifting is that it takes more of a turn on the steering wheel to pull it back straight then the other direction. But sense IV noticed the issue I see that it's damp around the lower dash like where the clutch and brakes stick through the lower dash. But when I open that cover down there I can't pin point a leak anywhere. Its like not wet but enough to make the metal shin wet and dirt stick. Must be vary small. Does any of you guys see any sign of dampness there. I'm thinking a line leaking
Edited by Mikez - 18 Jul 2017 at 10:34pm
This page was generated in 0.069 seconds.
