WD45 what powwr steering fluid
case310350 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote case310350 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 what powwr steering fluid
    Posted: 17 Jul 2017 at 10:09am
Need to drain and add power steering fluid on a wd45 tractor.  Do i use dextron II for the fluid?  What is the best way to drain the old fluid?  I put in hydraulic fluid and that does not work well need to drain it out
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 7:51pm
10 wt non detergentwas original
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 8:47pm
we always used ATF TYPE F in ours which they call MERCRON now. That was back in the 60s and 70s......that's what our book originally called for.
Edited by ctbowles58 - 17 Jul 2017 at 8:48pm
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Robert Musgrave View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Musgrave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 11:12am
On dealer installed Char-Lynn units, Dad always used 20W-20 in power steering, crankcase and hydraulics!  (Time period:  from about 1953 to about 1970's)  R. Musgrave
