PTO Guard
Lance/SC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lance/SC Quote  Post ReplyReply Direct Link To This Post Topic: PTO Guard
    Posted: 18 Jun 2010 at 10:13am
I've got my CA replacement guard all painted and ready to put on and got to wondering about the oil level in the back end.  Will it leak if I pull the two bottom bolts without jacking the rear end up?  If so, about how high should I raise it?  Thanks
Edited by Lance/SC - 18 Jun 2010 at 10:25am
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2010 at 11:24am
Do it quick,won't lose that much fluid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lance/SC Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2010 at 11:45am
LOL--I don't get in a hurry doing anything to the tractor.  As soon as I do, I screw something up.  I might ease one of them out and see how bad it leaks and go from there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2010 at 11:55am
Lance, get a couple of old bolts and cut the head to use as studs in the bottom holes. Take one bolt out at a time replacing it with the stud.  Once you have the guard in place, replace the studs with the original bolts.
Edited by CTuckerNWIL - 18 Jun 2010 at 11:57am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lance/SC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2010 at 2:36pm
Thanks, Charlie it worked just like you said.  Lost very little fluid.  Another trick of the trade learned.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2010 at 3:10pm
That's what we are all here for. I learn sompin almost every day too, even if I thought I knew it before but didn't. I'm starting to sound like Festus Haggen. Oh well most will get my point. LOL
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2010 at 7:03pm
I have heard of using a shop vacuum on the reservoir fill hole while doing such things. I guess it holds the fluid in while making the switchover. I don't think I would want to try it on a gas tank or something similar. Just a tiny static electric spark and you got mucho bigger problems!
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2010 at 9:48pm
Until you get it jacked up  you could have it drained and just put new oil in it!
