Allis 7060 pump timing
mbachmojave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mbachmojave Quote  Post ReplyReply Direct Link To This Post Topic: Allis 7060 pump timing
    Posted: 16 Jul 2017 at 6:53pm
Does anyone know where a good base setting would be for injection pump timing on a 7060 with dm4631 pump bigger injectors, and turbo? Going off of the manual, we went with 20 ° seemed to smoke too much had a hard time getting turbo lit, did ok at pulls, I set to 23° tonight, seems more responsive, less smoke.   Can anyone give me a yay or nay on weather I am doing the right thing?   Thanks, mike.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2017 at 8:22pm
need a lot more info to get a real answer = how many cc's what size injectors, and especially a 'bigger turbo' which is probably the issue..
Post Options Post Options   Thanks (0) Thanks(0)   Quote mbachmojave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 6:49am
Well if I remember correctly, the pump was set at 100 % which was around 200 cc's of fuel, the injectors were stock nozzles machined 25% larger, that is all they told me, and running 3lm turbo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 7:14am
Is the advance mechanism functioning or locked out??   Still functioning I'd say stock timing 16 to 18 degrees. If locked out, I'd say 34 to 36 degrees. Like Tbran said....not enough info.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 8:27am
I'd sure think the pump builder would have told you where to start with timing tuning.
As said above, the timing setting is very much dependent upon how the advance in the pump is set up, and the roller setting in the pump too. Good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mbachmojave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 9:41am
Advance is still installed, rollers are set as far as they could be shimmed, injectors were set at 2800 psi I believe, I don't know if I should go with the stock setting of the tractor with a 29 pump at 18° or the setting of the 31 pump on a 7080 at 22°.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 9:53am
The advance will always be installed. It's a matter of whether it is still functioning or locked in the retard position.  Your pump man should have told you where to start at for timing. How big are the injectors??  200 cc's isn't all that much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mbachmojave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 10:04am
Advance is functioning normally, I don't really know how much the injectors flow, all they told me was they would cut them 25% bigger then stock, I am only running farm stock classes so just trying too keep up with the red and blue ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 10:53am
If the advance is working as it should and he hasn't remarked the front timing line, I'd set it to whatever stock is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 10:55am
And if you don't have a 40 psi boost gauge to look at, you are losing good information without it. Depending on what turbo?? (you didn't say) I'd expect 25 psi??  from a stock turbo @ 200 cc's...........
Post Options Post Options   Thanks (0) Thanks(0)   Quote mbachmojave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 11:31am
3LM pulling turbo, I would suspect its close to 40 psi.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 11:57am
Well, you know what??? you HAVE NO IDEA what it's making without a gauge!!! You could have an air leak somewhere and injection pump timing has an effect on boost also.  With only 200 cc's I would not expect 40 psi from a 3LM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 12:43pm
The big reason we keep asking about the advance is, the 7030/50 had around 5* pump advance, the 7040/60 had 10*, and the 7080/7580 had a speed advance along with the addition of the light load advance, which adds even more timing advance with light loads. So, to pose a question of where to time a DM pump that someone modified, is really an impossible question to correctly answer. Your pump builder is the only one who can honestly give you a place to start.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mbachmojave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 1:13pm
Ok thanks for the help.
timmypuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote timmypuller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2017 at 7:21pm
My d 21 has a 450 roosa master with the big lines and Lazered injectors. Fuel pressure is 120 lbs and boost is at 44 lbs. Timing on the engine is at 36 degrees we think. Has a different cam shafts and the timing on it has been changed. This is a stock 3lm with a 2.30 intake and tractor is set at 3000 rpms. One of these days I'm gonna take that engine apart and see what's in it.
The mechanic that last had it apart said it had ceramic coated pistons and an odd camshaft part number. He set everything back together just like he found it.
Ed Hart was the original owner and in 66 it won the m&w 12,ooo lb championship.
Ed sold it to someone in southern Indiana area.
If anybody would know anything else about this tractor I would appreciate the info
