just my luck
mintenfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mintenfarmer Quote  Post ReplyReply Direct Link To This Post Topic: just my luck
    Posted: 15 Jul 2017 at 8:49pm
so, about a week and a half ago, i was cutting hay with the 200 and the hydraulics were getting sluggish so i went in to put some in. 3 gallons later i said screw it something aint right. go talk to the boss and he says unhook it and ill have another tractor delivered so we can  keep going on hay. so he buys an 856 and hauls the 200 to the local agco dealer. now they called us. they ran it for four hours on the dyno and not a drop. what is your guys thoughts. it was leaking oil directly under the flywheel and somewhere y the brakes before it went in
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2017 at 8:54pm
proves a corollary subsection, of Murphy's law.  Any problem brought to the attention of a mechanic, promptly corrects itself...Wink
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2017 at 9:06pm
Check the oil level in the rear-end bet you find it over full with hyd oil, if it's over full the seal is leaking.
kinghunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2017 at 9:12pm
Had two 190s that did same thing. Ran a hose from one drain plug to the other. Ran that way for several years. I know one is still that way being used
Post Options Post Options   Thanks (0) Thanks(0)   Quote mintenfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2017 at 10:14pm
don (MO) if the rear end is the fill on the right when sitting on the tractor, that is the one that is going low. would it go the other way?
