D17 Series IV lift shaft seals |
Post Reply ![]() |
vaAllis90 ![]() Bronze Level ![]() Joined: 22 Jun 2017 Location: Champlain, Va Points: 45 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Jul 2017 at 7:25pm |
My lift shaft seals are leaking on my Series IV and I am trying to figure out the best way to replace them. What has to be removed/ what is the correct order of removal to replace these o-rings? Thanks
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54135 |
Do you mean the seals in the lift arms?
bigmoe ![]() Silver Level ![]() ![]() Joined: 07 May 2012 Location: Eastern Kansas Points: 131 |
If you're talking about the lift cylinders, it's a known problem. Rebuilt mine once and it started leaking again so decided to replace them with cylinders off a 175.
64 D17 IV
50 WD |
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
Remove both lift arms, slide shaft to left then replace right orang, do same to other side. Be good time to replace shaft bushings. MACK
Post Reply ![]() |
