Power steering coupling
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Topic: Power steering coupling
    Posted: 18 Jun 2010 at 7:52am
Does anybody have the coupler that is between the generator and pump for power steering on a WD45D that they would sell. It needs to be in good shape because the pump shaft is worn a little.
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 1:25pm
I can't find one anywhere so I was checking it out and a 5/16 12 point fits good and tight over the splined shaft that is 12 point also, so I bought a deep well socket cut it to length and put the roll pin in the center to hold in place just like the original steel one. Try it tonight raking hay. I know that sounds like some major riggen doesn't it.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 1:37pm
It sounds like a pretty Good solution to me! LOL
WC, CA, D14, WD45
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 2:38pm
I would have a new one. 785-3543-2392
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 8:57pm
  we have new repos in stock   1-574-342-4545
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 8:58pm
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 6:21am
Well I have bigger problems, the shaft on the gen. is real good but the pump is stripped pretty bad and my pump off of the parts tractor isn't much better.I will get the right coulping off one of you because the socket is to thin walled for me and I may have to find pump also.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 8:37am
Agco still had the shafts a couple of years ago...I think they were around $160.
ALLIS EXPRESS!
This year:
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 10:21am
WoW! they don't give them away do they
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2010 at 8:48pm
 can take one to  wheat harvest thur eve  will be there thur.eve fri. sat aft. coming home sat eve
