HD5G hydraulic pump
DavidnTenIll View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidnTenIll Quote  Post ReplyReply Direct Link To This Post Topic: HD5G hydraulic pump
    Posted: 11 Jul 2017 at 5:30pm
Am looking for a usable Vickers or Hydreco pump for Hd5g.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2017 at 6:06pm
I have the spare off my 7G if it is similar?
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidnTenIll Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2017 at 7:08pm
I dont know about HD7. Numbers i have for pump is either a 2025G1B1 Hydreco or Vickers V300 28. Should be a tag on your pump. Thanks, David.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2017 at 8:08pm
Will dig it out tomorrow or Thursday as is in the barn and check.
Decided to check parts book, mine is a Tyrone, not Hydreco or Vickers
Edited by DMiller - 11 Jul 2017 at 8:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2017 at 10:31pm
The vickers is a vane pump and was used on the early units - the problem is finding the matching drive plate to fit crank pulley on that pump .
 I have a spare pump but the internals are scored so questionable, in my HD5 pile  .
I did pick up a Hydreco about 2 years back at Hutch but have not looked at it since - its somewhere in my pile of spare things - one of these days projects .
Finding a 32 GPM pump @ 1800 RPM presents somewhat a problem
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2017 at 5:36am
The hydraulic pump on my HD5B is much smaller than the pump on my HD6G.
Dave or Rob (800) 398 3448 wrights@adams.net had an hd5 pump last November when I bought parts from them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2017 at 5:39am
Wrights also had the pump drive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2017 at 8:38am
oops the 5G used the 32 GPM pump - on a B with only blade lift needed GPM is a lot less
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidnTenIll Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2017 at 7:44pm
Found a Prince Hydraulics 32 gpm pump on surpluscenter.com that I have decided to go with. Gear pump 2500 psi max. 32 gpm at 2000rpm for $389.00 will require some mount and coupling modifications. Appreciate the posts and info. Thank you all , David.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2017 at 5:13am
Post pictures of your conversion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2017 at 6:15am
Are you considering a 1 3/8 six or 21 tooth PTO pump? The crankshaft drive would be easy. Please post the prince part number.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidnTenIll Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2017 at 5:13am
Prince part # SP25A63A9H2L is the number of pump were going to try. It will require fabricating/machining of pump mount bracket and a coupling modification. David.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2017 at 6:45am
Your SP25A63A9H2L pump is aluminum with O Ring Boss fittings. Get short lengths of ORB pump fittings on one end so that you can make the hose conversion at a convenient place under the rock guard.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidnTenIll Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2017 at 8:08am
Yep. Planning orb to jic37° fittings. Trying to figure best way to put some filtration in hydraulic system. Quite polluted. Sucked out bottom of my left tank with a tube extension. Lot of sludge/dirt. No access to right tank other than return and crossover. I know they had a factory option for filters but not sure where they plumbed in. David.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2017 at 4:10pm
I suggest a short hose on each port of the pump because the pump is aluminum. You have a good chance of damaging the threads on the pump when it is attached to long difficult to align hose. The hose attachments to the pump are difficult because of the rigidity of the hose and the near by 90 degree bends. I have done this on my HD6G's. I am thankful for the remote connection whenever I have to deal with the hydraulics.
Good luck Post pictures
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidnTenIll Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 8:05am
Thanks for the suggestions. Will keep in mind.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 9:20am
Can cut a hand clean-out hole into tank near base and then make a new cover for it to bolt on, seen that done a few times. but requires drilling and tapping.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 9:33am
Did you check under the valve body for access to right tank ?
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidnTenIll Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 6:02am
Yep but it looks like you have to remove valve assembly as it looks like that's where valve returns oil to tank. Thought about cutting clean out access too. Oh well more to do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2017 at 12:28am
A screen filter on the intake  as a filter of any other kind would restrict flow , and you could rinse the tanks through the top - yes the oil return is into right tank under valve body -
 No good way to filter the return side - and high pressure filter is a real chore
Flow pressure should be between 1200 and 1500 PSI - unsure if cylinder seals will stand much over that for extended time without heat buildup
