Combine Power Steering Question
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: Combine Power Steering Question
    Posted: 10 Jul 2017 at 1:24pm
I'd like to add power steering to my All-Crop Super 100, and I've been thinking of fabricating my own system. I've seen them homemade a few different times, and if a farmer back then could do it, so can I. They had a factory power steering kit, but I've only heard of 2 in existence, and I've never seen one in person. I couldn't afford one anyway. A friend of mine sent me a photo of Arland Lepper's power steering setup on his Super 100, and while that was helpful to see, I'm still confused as to how it works. Here is a photo.
Looks more like "power assist" than true power steering to me.
I've seen Ford and Massey Ferguson tractors with a similar setup, but my question is how does it work? I understand the pump driven off the motor, but how does that piece inline with the drag link work? What makes it direct the fluid to one side of the cylinder or the other? What is that piece even called? Ok...now I sound really dumb, but I want to figure this out. It can't be too complicated, I've just never worked or been around anything like that before.
Thanks
Edited by CrestonM - 10 Jul 2017 at 1:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 1:34pm
how are you gonna build muscles if you do this? or isit so you can turn the steering tires faster as yer churning mud?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 1:38pm
Next time you're at Hutch I'll let you sit there and steer it with one arm...then you tell me what you think Lol! Wink
As for mud....maybe I should put a FWA axle off a 5000 series Allis on the back. Make a Mud Hog out of it! LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 1:41pm
one arm???? ain't you gots 2 arms????
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 1:44pm
It looks to me that the valve is on the drag link. I think that when the drag link pushes the valve it opens the side to direct the fluid to push out the ram. When the valve is pulled it opens the side to direct the fluid to pull the ram back. When the drag link has no pressure back or forward then both valves are closed.
Why do you want power steering for?
When the hopper is full on my sp100 it still steers easily.
Thanks & God Bless
Dennis
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 2:26pm
The valve is similar to the one on Ford 900 row crop tractors. They call it a control valve. A lot of cars in the 50's and 60's used a valve like that as well as some medium trucks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 2:32pm
From my experiences you generally have to leave one arm on the variable speed if you're cutting anything very heavy. Slowest speed isn't quite slow enough, so you kinda override the system by holding the lever further forward than the last notch on the rear section of the quadrant which allows you to barely creep. Yes, I know you could just not take a full swath, but sometimes you still only have 1 arm available.
Dennis...I just think it would be neat to have. Certainly don't "have to have it", but I think it would be nice. They're certainly not the worst steering, but a lot harder than a Gleaner. Thanks for the explanation. I was beginning to think that as well, but I wanted another opinion.
Leesok View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leesok Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 2:56pm
Have that setup on an old F. Come take it off and it's yours. The F would steer with one finger and never gave any trouble.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 3:18pm
Cant beat that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 3:40pm
Awesome!! Where are you located? Can you send me a photo of it?
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leesok Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 4:13pm
In the area of 73444. I can text pic to you, just need #. You will have to make it fit your 100, but the 2 cylenders are identical to the ones in your pic.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 5:27pm
If you set it up like that shameless might just reverse the hoses when you aint looking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 6:42pm
Here you go.LOL
Add power steering to your tractor
Edited by DennisA (IL) - 11 Jul 2017 at 7:58pm
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 9:45pm
Looks just like the one I put on mine almost 50 years ago.
Same setup as Gleaner used until the F G K.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 11:08pm
Neat! So a kit from an E,A,C, series combine would work too, you think?
An F is different, eh? Hm. Guess I just need to get pics of the different units and compare them.
Thanks
Edited by CrestonM - 10 Jul 2017 at 11:11pm
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 11:10pm
IMO keep it original. Then you will be all buffed out and get all the ladies, and this winter can go wrestle Shameless for the controls to the snow machine and win.
Then Shameless will go run the power steering-less All Crop and come back for a re-match. :)
But seriously, something is only original once. :)
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 11:16pm
Lol, that's true! I'm usually a member of the "correct police" (unless it's something that really needs changed) and I may or may not get around to doing this anytime soon. I'll just keep looking for the real deal I guess. If anyone knows of a 100 factory power steering kit for sale, let me know. Like I previously stated, I doubt I could afford one anyway, but it would be nice to know how many are actually out there. Like I said, I've never seen one in person, so they can't be too common.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2017 at 7:27am
Yes, any of the older combines used that same valve. Case used it on some of their combines maybe some other colors used it also. I put the same setup on my Chevy grain truck. If you weaken the centering spring, they will steer easier.   MACK
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2017 at 7:34am
i have a special attachments book for my 100 and the power steering pump and bracket are the same as the power steering of a WD45 that mounts on the front of the motor! the reservoir tank mounts at the back though somehow! I can get you pics of the parts pages if you want!
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2017 at 10:47am
Thanks, but I have that book too. I'm aware that part is the same, but the control valve, cylinder, etc. are the hard things to find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2017 at 12:32pm
I took that valve and cylinder off a Greene combine and installed on my A2.Didn't know if existing hyd would work it or how to plumb it so I added a pulley to drive pulley and plumbed a GM car PS pump.
Roger (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2017 at 2:56pm
Have a salvage MM uni-tractor that has the power steering set-up still intact. Cylinder, motor and pump driven by crankshaft pulley with belt. Neighbor used one of these to put power steering on a self propelled silage cutter some years ago and it worked well. Send me a pm if you're interested in knowing more details.
