190 XT pulling better this year
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Topic: 190 XT pulling better this year
    Posted: 08 Jul 2017 at 5:59pm
put a BW s200 on for this season , seems a lot stronger , 4th low(7th) still wondering if I should cut the fuel back some.
Edited by Beirnesy - 08 Jul 2017 at 7:02pm
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
Allisplumber View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisplumber Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 6:35am
I run a 200 and what helped me was putting a smaller exhaust housing on the turbo and driving the turbo harder so you don't fall under the turbo on the end , I don't know what you are building for boost ? Allischalmers 301 engines don't breathe very well , doesn't look like to much fuel to me , step the exhaust down one step and try that , thinking that will help you a lot , I build around 48 psi of boost and spin out at the end every time .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 9:18am
Good looking tractor,, it definetly fell off at the end , id try Allisplumbers idea, I wouldn't back the fuel down, its a good black, its keeping the flame down , flames out of the stack look cool, but it means stuff under it is HOT !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 4:40pm
Thanks for the advice, it is the .83 A/R turbine housing
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisplumber Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 5:59pm
I would step that down 2 sizes , the 301 motor will not over turn that big turbo unless you have some major head work done to it , I'm only running a .58 on mine but my turbo is smaller then the s200 , good luck hopefully that will keep it alive for you
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 9:53am
The .83 is pretty small. I think you drowned it with fuel at the end. That pump had enough fuel to feed a 426. It takes heat to drive the turbo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 12:08pm
should I turn torque screw in a 1/4 inch, or would  that cause complications in other sections of that built pump  ? Thanks for advice as well ED.
Edited by Beirnesy - 10 Jul 2017 at 12:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 1:11pm
Ice water intercooler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 1:47pm
Thats what my 18 year old son keeps telling me, and you can never go wrong with a cooler charge of air, but not allowed if I want to  pull in OTTPA, although when your AC is 100 C I less than rest the class, maybe they should allow.  I should mention  it makes 55 lbs  boost quite easy .
Edited by Beirnesy - 17 Jun 2018 at 8:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 2:03pm
try running the torque screw in, and a 1/4" would make a difference I'd think, but I haven't seen that pump in so long, that I can't even guess where the screw was set. I would have left it wide open last time I had my hands on it. It will not hurt anything.
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2017 at 7:19am
Looking good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2017 at 12:33pm
This weekends hook, having fun
https://www.youtube.com/watch?v=mT1iReGOfmI
Edited by Beirnesy - 21 Jul 2017 at 9:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2017 at 1:50pm
That's the way it's done! Very nice!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 7:37am
Good looking 190. What tires are you running? Is the rear end stock and if so have you had any issues? I pull mine in the stock farm class. Ed has done his magic on the pump, and I put in a 6 puck clutch. I had plenty of power and spun out. Previous owner put tires on from the local coop. Okay for the farm but not for pulling. Would love to have some Firestone radials.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2017 at 9:21pm
tires are Good Year dyna torque, they where cheap, not my favorite tire.  Has new 3rd and 4 th A&I gears, sliding collar, shift fork.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2018 at 10:54am
2018 UPDATE.  New steel flywheel and double disc clutch from ATLAS tractor, (very smooth instalation and works great).  Boost pressure runs 52-54 psi and exhaust pressure at   32 psi.  BW S200 57 x 61 with .83 exhaust housing.  should I go with tighter exhaust housing ?
first hook  in 3 high  track very tight,  second hook in 4 low.
Edited by Beirnesy - 17 Jun 2018 at 12:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2018 at 2:12pm
From the catalog I have the .83 is the smallest A/R ration housing offered for the S200. With the exhaust pressure being as low as it is that would probably explain why it dies off so fast when the load hits. Almost think the 52mm S200 would have balanced better. Everyone thinks bigger is better.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2018 at 5:35pm
shorter tire will sure keep the rpm's up. even if you went up a gear ?
