190 weak 3 point |
Dakota Dave
Topic: 190 weak 3 pointPosted: 08 Jul 2017 at 12:25pm |
My 190 has a weak 3point. Im moving the pallets of lumber for my new shop. so I put the Pallet fork on the WD 45. it lifts the front of the tractor about 3 feet off the ground and teeters the stack of lumber. So I put the pallet forks on the 190 it wont budge the stack of lumber. I picked up one end of the pallet of steel with the WD45 loaderand a strap so i could get the forks under it. the 190 wont lift it. I dont have a factory three point but a conversion on the snap coupler setup. But I really think it should lift more than it does. is there a relief valve stuck somewhere that I should be able to find?
DrAllis
Posted: 08 Jul 2017 at 3:47pm |
Pressure at any remote outlet when holding a lever into raise or lower should be 2,000 to 2,200 psi with engine half throttle or above. If lower than that....a weak 3 point hitch.
Dakota Dave
Posted: 08 Jul 2017 at 10:11pm |
Thanks I'll try to get a guage next week when I'm at the farm. If I speed it up to 1500 rpm it works much faster.
DrAllis
Posted: 09 Jul 2017 at 12:24pm |
Hyd on a WD45 will work at an idle. 190 XT at an idle won't do much at all.
