Power Director Rebuild Video
 Rating: Topic Rating: 1 Votes, Average 4.00  Topic Search Topic Search  Topic Options Topic Options
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Topic: Power Director Rebuild Video
    Posted: 08 Jul 2017 at 1:10am
I finally got this video project done. I started it early this spring Its by far the longest and most difficult video to date. 7hrs of preparation, 6hrs of video, 3hrs of editing & 21hrs of uploading. I tried to made it as short as possible, but it ended at 52 mins long and a file size of 5.7gb. It covers the disassembly and reassembly as well as setting the shims for the high and low sides. I will be adding a 2nd video of just the shimming so if that's all someone needs to see they don't need to watch or skip through the complete rebuild video.
I hope this video is of help to many.
Thanks & God Bless
Dennis
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2017 at 10:04pm
Dennis,
What a great video!!!
If I may suggest, when measuring shims, I do like you do, and put the clutch pack on the trans input shaft, but when changing shims around, I go back to the bench and loosen all six of the bolts together, it keeps the shims from falling out, AND makes shim swapping significantly easier.  Just my thoughts, but none the less, makes it very clear what the procedure is, and helps those who might be apprehensive feel a little more comfortable with the work.  The hardest part of a power director rebuild really is getting the thing out of the tractor, and that really doesn't take that much either.
Still in use:
ocharry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ocharry Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 11:38am
hi dennis,,i watched some of your video,,,man you did a great job!!!!
how much would you charge a guy for a CD copy of both of you videos,,,i for one would love a copy
ocharry
Hazelsparks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hazelsparks Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 3:56am
great video! If you want to edit your videos to be even more engaging, download kinemaster at Techbigs.com, this is the video editor most loved by many editors
Edited by Hazelsparks - 15 Mar 2021 at 11:33pm
studer automotive View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 5:12am
what’s it cost to rebuild one of those? Are the parts available aftermarket?
a-c 185-d y/r cab turbo soon
99 f-250 7.3 4x4
86 mustang5.0 owned since 8/93
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 6:16am
Thank you for making this and thank you for sharing !
This should definitely be in the "Knowledge Base" section !
This page was generated in 0.093 seconds.
