210 Alternator charging issue |
Oldoug
Topic: 210 Alternator charging issuePosted: 07 Jul 2017 at 10:16pm |
Tonight I put a new rebuilt alternator on my 210...I have been fighting dead batteries for the year I have owned it. I have new batteries and new cables and new alternator in it now. I volt tested at the alternator and the battery and it shows it is not charging (12.3 volts). I have power to the alternator and have tested the ground wire to the alternator also...if I unhook the field terminal it should charge no matter what correct? It still only reads 12.3 volts. Alternator is spinning good and freely. Did I just get a bad rebuilt or what else can I test. Thanks for any help.
Matt Folkers
FOLKERS RESTORATION Restoring vintage things to last so the future can enjoy our past. |
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 07 Jul 2017 at 11:38pm |
I haven't worked on our 210 yet, it is still a project waiting, but by the looks of the parts book is has a remote voltage regulator up under the dash cover like the other hundred series, and Two Twenty/D21 tractors. I would look there. Also check your grounds on that regulator.
Still in use:
HD7 WC C CA WD 2-WD45 WD45LP WD45D D14 3-D17 D17LP 2-D19D D19LP 190XTD 190XTLP 720 D21 220 7020 7030 7040 7045 3-7060 Projects: 3-U UC 2-G 2-B 2-C CA 7-WC RC WDLP WF D14 D21 210 7045 N7 |
DougS
Posted: 08 Jul 2017 at 3:56am |
You need the field terminal to be connected. I presume you have an external regulator, since you mention the field terminal. If you don't have an external regulator and your alternator has a field terminal, I would presume that you have the wrong alternator installed. If you have an external regulator and it is connected, that regulator may be your problem.
ranger42
Posted: 08 Jul 2017 at 8:59am |
I had the same symptoms on our 210 it was voltage regulator on the hood under the cowl cover like others guys have said. I did have one other time we were having trouble and it was a bad ammeter gauge.
