WD-45 Manafold installation
BradH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BradH Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 Manafold installation
    Posted: 07 Jul 2017 at 6:22pm
Okay, I'm sure it's been asked on here about a hundred times already and you guys are getting tired of explaining things to me.  But I don't have time, money, or patience to do the job wrong.  So I'll ask again.  Now that I have to old manifold off, and the studs removed what do I need to do to install the new one?  I've got the studs and gaskets already.  What's the order for gaskets and sealer?  Also, do I need some kind of a seal between the top of the carb and the bottom of the manifold?  I didn't really see any evidence of one when I took it apart, but that's been a couple of months ago now.  Also, what's the right amount of torque I'm looking for when tightening?  Sorry for all the simple questions, but I'm not really a mechanic, I'm only pretending.  That's why I'm here, to ask someone who is.
Thanks again,
Brad
Warning! Blind man with a tractor! Head for the hills!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 9:44pm
Yes, there is a gasket that goes between the carb and manifold.  The old one was so thin you probably didn't see it when you took things apart.
Putting in the studs is the easy part.  This can be done first.  Thread them in snugly - don't snap them by tightening too hard.
I have not had to replace the manifold gaskets on the 226 before, but make sure the surfaces on your head are perfectly flat and smooth, otherwise all of your work is wasted.
If you don't already have a service manual, get one.  It will help with this job.
Good luck!
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 10:32pm
I have put brass nuts on and stainless steel nuts... haven't needed to take any manifold off to find out which was a better nut to use... and I used thick ss washers too. Often wondered what would be wrong with stainless steel studs too...
  make sure you have lots of good metal too on manifold... some foreign made ones don't have very much metal on the ex. ports.
what66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 11:03pm
My service manual says to torque them to 20 ft lbs.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2017 at 4:06am
Odds are the stainless nuts would seize on the stainless studs very quickly. I've seen it happen as the nut was being tightened on the bolt when no anti seize compound was used.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2017 at 6:58am
First thing to do is lay a good straight edge across the head surface and check with a feeler gauge to make sure the head is flat, or you'll be wasting time putting anything new on it.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2017 at 9:01am
As I recall, some, if not all of the manifold studs thread right into the water jacket of the head. So....thread sealant is needed there.
I like good ol' permatex #2 for that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BradH Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2017 at 10:51pm
I cleaned the face of the head up today.  It looks pretty good.  The straight edge shows it to be in good shape too.  I've got a tube of permatex 2 for the studs, is that what you'd recommend for the gaskets too?  Also, do I need it between the gasket and the head, the gasket and the manifold, or both?  Or do I not need anything other than the gasket between them?  Again, sorry for asking questions like this, I just want to make sure I do it right the first time.
Thanks,
Brad
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2017 at 11:31pm
brad,mr tucker is right about the head surface,also check your manifold surface as  well.those manifolds in time will get surface build up and you can crack your new manifold if it the case.also if you can locate some FELPOR C5A anti sieze use it.it was specially formaulated for the c5a military  aircraft engine mount bots that were usually seized up on an engine change.this stuff really works....sorry,i forgot you are installing a new manifold.still use the anti sieze on the nuts
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 10:20am
The only sealer I would recommend for the gasket is copper coat.
The silicon would just burn off on the exhaust ports.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 1:10pm
the port gaskets go on clean and dry. sometimes bending the sidewall of sealing ring a little in a couple places allows it to grip the manifold so you dont need 6 arms when installing
Post Options Post Options   Thanks (0) Thanks(0)   Quote BradH Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 9:22pm
Okay, thanks.  I think I've got everything I need to get this done now.  Hopefully I can get it on in the next week or so, if I get time.  Started building fence and cleaning up pasture this weekend so I'm going in a lot of different directions right now.
Thanks again,
Brad
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 9:30pm
don't put anything on the port gaskets' just do the bolts wear they go in the side of the head' like steve was saying' should work fine. after you run it for a few days' check the bolts again.
