Forage Harvester&Blower "quiz"pg2
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: Forage Harvester&Blower "quiz"pg2
    Posted: 04 Jul 2017 at 10:57pm
Didn't realize it was Tuesday, I normally post these on Monday
Well here's pg 2 of the test from jan 30,1957
6.    Incoming material is controlled. To within:
          ( ) a. 2 inches of the shear bar.
          ( ) b. 6 inches of the knives.
          ( ) c. 4 inches of the shear bar.
7.    Most competitive forage harvesters have:
          ( ) a. No means for protecting cylinder such as we have.
          ( ) b. narrow throats that don't need any means of protecting cylinder.
          ( ) c. Much simpler, more effective system of protecting cylinder then we have.
8.    The flywheel type of cutter has a:
          ( ) a. Variable cutting edge speed, but vary little deflection compared to the AC.
          ( ) b. constant cutting edge speed, with greater deflection than in the AC.
          ( ) c. Variable cutting edge speed, with greater deflection than in the AC.
9.    One of the "built-in" reasons for more power requirements in a flywheel type is:
          ( ) a. Knives cut, but don't deliver material- need blower paddles too.
          ( ) b. knives both cut and throw material.
          ( ) c. Material comes into machine in a wide, thin stream.
10.    The lawn mower type cutter:
          ( ) a. Uses the same cylinder principle of design as the AC.
          ( ) b. is very similar to the flywheel type.
          ( ) c. is completely different in every way from either of the other two types.
11.    One of the main disadvantages of the lawn mower type cutter is:
          ( ) a. The fact that it is so heavily built.
          ( ) b. The fact that it needs a blower or conveyor with it to deliver material.
          ( ) c. Knives can't be sharpened in the machine.
12.    The AC chopper cylinder:
          ( ) a. Lightweight for easy pulling.
          ( ) b. small in diameter, heavily built, with spiraled knives.
          ( ) c. 3- foot wide, big diameter and has a high deflection.
Hear you go enjoy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 11:07pm
Anybody goin to give it a try
This page was generated in 0.031 seconds.
