WC carb
Loren-ia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Loren-ia Quote  Post ReplyReply Direct Link To This Post Topic: WC carb
    Posted: 03 Jul 2017 at 10:29pm
Got an issue with a Marvel Schebler carb on a WC. It had sat for years and was a mess when I took it apart, full of rust and gunk. Soaked it good got it cleaned up got a new needle and seat, float and gaskets, blew out every port and put it back together. It will fire and then die and if you let it sit a little bit it will fire and die again but if you keep cranking it won't do anything. I opened up the drain and there is a good steady stream of gas coming to the carb. The float is set at 9/32" which is what the IT manual said. Took it apart and cleaned it for the third time and no change yet. I borrowed the carb from my brothers WD just to make sure the carb was the problem and it runs pretty good with that carb, too bad I have to give that one back. Anyone got any idea what I might be missing here, could it be the venturi?
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2017 at 6:59am
Sounds like the main jet is totally plugged. Did you try to open the main jet a couple more turns? Does it help to have the choke on all the way or partially?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Loren-ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2017 at 7:59am
I have blown air and carb cleaner through the main jet so I don't think it's plugged but I will take another look. I have backed out the adjusting screw a few more turns, didn't help, my son thought I should take that screw completely out but I didn't think it would work that way so I haven't tried that yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2017 at 8:39am
You need to run a small wire through all of the passages. Carb cleaner and compressed air will not always clear the passages.
This page was generated in 1.078 seconds.
