WD transmission gear shift
Lew View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lew Quote  Post ReplyReply Direct Link To This Post Topic: WD transmission gear shift
    Posted: 03 Jul 2017 at 10:05am
Did AC change the transmission gear shift from straight to curved on the WD? I just pulled my WD home and found that it is a 1951 not a 1948 as I was first told. I was given an axle casting number that I checked on instead of the correct serial number. If the AC Company changed the gear shift what year was that change made?
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 10:19am
The (very) late WD's and all WD45's had the curved shifter. I believe the change from straight to curved took place in the 1953 model year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 12:31pm
Curved gearshift change happened at s/n 127,007 and up.  The transmission was of a constant mesh helical gear design instead if sliding spur gears in the straight gear shift models.  The older WD transmission was essentially a WC transmission moved rearward.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 1:31pm
The change took place in 1952 and at serial number as doc quoted
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 1:49pm
According to the serial number reference (from this site), the last WD serial number built in 1952 was 126981. If the change was at serial # 127,007, it had to be in 1953.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 2:07pm
You may be right, I think I was mixing up the high cylinder head with the gear shift change. I think it was the high cylinder head that came on in '52.
Wink
I am a Russian Bot
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 4:48pm
There was a break in serial numbers in 1952:
First batch:        105182-126931
Second Batch:    127007-131242
The change in transmission style coincides with the second batch of serial numbers.
The "Tall" head was introduced in 1951 with "Engine" Serial #289001.
I have my Dad's '51 WD with "Engine" serial #309267 and it has the tall head.
