D17 belly clamp help?
Hitman79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hitman79 Quote  Post ReplyReply Direct Link To This Post Topic: D17 belly clamp help?
    Posted: 02 Jul 2017 at 9:17pm
The hook that goes into the eye on draw bar is just hanging down I know that's not correct. My question is what holds it up? There is a small coil spring under there up by the step that's un hooked but also noticed there is a funny shaped looks like some kind of tension or cam type spring I'm going to call it that looks loose or maybe broke in the front of the bell. Any help is appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2017 at 9:28pm
parts break down at agcopartsbooks.com....go in as guest viewer
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2017 at 9:42pm
There is a spring that goes around hook then hooks to a pin in bell.   MACK
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2017 at 11:23pm
Look at the lower pic of the hook you can see the spring that is broken on your tractor, the top pic shows the AGCO part number for the spring.
Edited by Don(MO) - 02 Jul 2017 at 11:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hitman79 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 12:07am
My spring looks like the ones in top pic. Are thoes correct open on one end? If they are maybe my spring came out of place some how. How do they go back togeather mine is loose in there. Or do I have to take the assembly off tractor? Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 7:31am
One of two things, one the spring cross pin in the bell is out or the ends of the spring have worn off letting the spring become loose inside the bell. I'd order a new spring and replace it. It can be replaced with the bell on the tractor, pull the drawbar off first then look at the way the spring is sitting in my shot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hitman79 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 8:02am
I had my hands on that spring yesterday but didn't know what it was supposed to look like. Does the open end just wrap around the pin or go into something? When you talk about the pin being wore out your talking about the big pin in pic not some smaller pin that holds the spring in place correct. Thanks.
This page was generated in 0.316 seconds.
