Hydraulic oil
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic oil
    Posted: 01 Jul 2017 at 5:56am
I noticed once again that the hydraulic oil in my HD6G has turned milky white indicating that it has accumulated moisture. Is there any way to remove the moisture and save the oil. I don't use the machine that often so replacing 15 gallons of hydraulic oil each spring is a problem.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2017 at 8:20am
Try one of those magnetic oil pan heaters to heat oil and a fan to circulate air above oil. Never tried it , often thought about it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2017 at 8:55am
Only other option is drain, filter for water and allow to settle then skim off good oil. Nothing I know of to remove water entrained in hydraulic oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2017 at 9:21am
new oils hold water in suspension... normally you can not filter it out... Only way is to heat the oil and get the water to vaporize and come out.. Don't need to boil, but needs to be plenty hot. Could try a pan heater, or drain oil, put in a 55 gallon drum over a wood fire and cook it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2017 at 10:59am
time might allow separation - or centrifuge - or the heating to a controlled temp to vaporize the oil water mixture to release the water .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2017 at 7:03pm
its tricky thing to do.  water boils at 212ºF, but oil burns at about 250ºF...
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2017 at 10:49pm
I'm not sure you have moisture but what I would do is if you haven't ran it for awhile then loosen up your drain plug just enough to get a drip out and if there is water it should drain out first. just my 3 cents worth
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2017 at 3:39pm
Have no problem with water settling out of motor oil but I drained some milky hydraulic oil out of a CA two years ago and put in milk jugs, the water is yet to separate and the jugs have not been moved.  Next time I touch the jugs they will be making a trip to town.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2017 at 10:14pm
Don't sound right that it just accumulates water setting around.Set out doors? leaky boot somewhere? Even with little use,might be cheaper to replace annually VS running as is....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2017 at 6:27am
We have hot humid days and cold nights. Every morning any massive metal object is wet from condensation. Any unprotected steel rusts. This is especially true of my steering clutches.
This page was generated in 1.160 seconds.
