Marvel-Schebler carb on a CA
Dean(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean(IA) Quote  Post ReplyReply Direct Link To This Post Topic: Marvel-Schebler carb on a CA
    Posted: 29 Jun 2017 at 8:29pm
Does anyone have the dimension on the throttle shaft arm,center to center,
from the throttle shaft to the governor rod hole?
thanks,
Dean
wd4d5 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wd4d5 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2017 at 11:19am
I'm not sure if it's the same as a C if so i can take a dimension off of mine and let you know if you still need the info.
Jim-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2017 at 3:48pm
What is the correct Marvel-Schebler carb TSX number for a CA?
'61D17, '51WD, '51CA, '41C, '49C, Woods 5'&6'Mower, 6'Blade, CA-Plow, CA-Cultivator, 3-Btm snap-coupler plow, 4-row planter, WD 4-row cultivator, 80R mower,#7 mower,B/C mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2017 at 8:24am
I believe the TSX-670 is the popular Carburetor for the CA. There are some other Carbs that could've come on the CA also. TSX-470, TSX-486.
Steve@B&B
