Snap Coupler Dirt Bucket Operation.
DakotaSteve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Topic: Snap Coupler Dirt Bucket Operation.
    Posted: 26 Jun 2017 at 11:05pm
Does anyone have a video of one of these in action?
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2017 at 9:59pm
No video, however I use mine all the time.  It's also reversible.  Has a manual trip however one of the handiest snap coupler implements I've ever used.
michiganmarty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michiganmarty Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2017 at 10:01am
do others have difficulty hooking this on?  i put mine on a d14 if it matters.  have to be exactly in line.  and i have to pull the pins to have enough flexibilitty to hook the top latches on, and the raise it, and put the pins back in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2017 at 10:09am
A flat level surface for storing is probably a good thing for hooking and unhooking. My SC blade can be a pain to connect because it doesn't have a home that is flat and level with where the tractor sets when hooking up. The blade can be tipped to cut heavier on one side and that will complicate things when hooking up.
 If your dirt scoop has been tweaked out of level a bit that could cause problems ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 12:06am
They can be a pain to hook up by yourself . I am sure there is a video of someone backing up and connecting lift latches from the seat ,,,, but I have never been able to . The cross bars on lift arms keep from them from swinging to the side and make it hard to hook up . I used mine on a Ser I D-17 and moved a lot of dirt with one . Turned it backwards and it was like using a little skid steer . Slower than a bobcat but faster than a wheelbarrow.
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 10:24am
Pat, do you think it could be the way that we're build Big smile Just saying Kenny L.
This page was generated in 0.131 seconds.
