6060 Dropped RPMs
Eddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Topic: 6060 Dropped RPMs
    Posted: 26 Jun 2017 at 7:19pm
This morning was going to bush hog some acreage. The fuel tank was below half so I topped it off and started. After about 30 minutes it lost power and would not run over 1600 rpms. I took it to barn, changed fuel filter. No help. Drained about 3 gallon from fuel tank, no water, pretty red fuel. Disconnected fuel line at filter and blew air back thru tank. No help. Runs smooth at 1600 rpms for about 3 minutes then starts running rough for a little while then quits. Is the fuel pump built into the injector pump? Could the injector pump be the problem???? Thanks in advance for the help!!
Allis Chalmers 6060
10' Howse Rotary Cutter
5' Tiller
5' Box Blade
4' Aerator
Ferris Zero Turn Mower W/10' fold up sprayer
John Deere 455 Lawn Tractor
John Deere 955 w/loader &
60" belly mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 8:45pm
governor flex ring coming apart and plugging return....
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 8:46pm
Dads 6060 did nearly the same thing. Surging and also puffing white smoke. Had the pump rebuilt and it resolved the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 9:49pm
Is this in the injector pump?
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
kinghunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 10:34pm
Yes time for pump rebuild
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2017 at 2:51am
Is there a link that tells how to make sure it's timed before removal of the pump or can someone tell me how to do it?
Edited by Eddie - 27 Jun 2017 at 6:44am
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2017 at 7:50am
simply take the timing cover off the pump by the nametag, turn the engine by hand until the 2 lines match up with each other. Then it's just a matter of disconnecting lines and linkage, and the wire. Shaft can stay in the engine. Upon re-installation, look at where the engine is positioned, so you can correct any minor timing errors. It may have been off a degree or 2.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2017 at 8:03pm
Thanks everyone, found someone to rebuild it. Now just to get it off and get it to him!!!
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2017 at 8:19pm
Ed was your best bet to rebuild it...trust me, he is really good.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2017 at 9:33pm
The shaft, timing gear, spring and thrust button have to come out the front before removal. They are behind the inspection plate below the alternator. Make sure to mark drive gear teeth before removing it. Just did one a month ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 9:10pm
Picked it up from the re-builder this afternoon. He said that the flex ring was the problem and that I should blow out the return line with air before reinstalling the pump. Should get it installed tomorrow morning!!!
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 10:49pm
Once you get it all bolted up,back engine up 1/4-1/2 turn then rotate fwd till correct degrees at pointer,then see if marks in pump are in line.May need a tweak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2017 at 3:16pm
Got it reinstalled all lines tight, alternator back on but ran out of gas before trying to start it. Not in the tractor, but me. When your 72 with Afib you don't have a lot of gas. Will get it started tomorrow!!!
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2017 at 7:43pm
Eddie it looks like you need to join Dale and I on the front porch and watch the world go by.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2017 at 12:31pm
Leon, I frequently have to do some "major mechanic work." Putting a rear end in a recliner!!!!
Got it running and bush hogged about 8 acres before I got rained out!!
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 9:11pm
How did she run? We also noticed a little more power after the pump rebuild. The power in my XT was even more drastic, turned it into a totally different tractor. Obviously for the best.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 6:19am
It runs great!! I thought more power, then I thought just my imagination. But maybe it was. I was pulling 10' bush hog in some really heavy grass and weeds.
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 9:03am
Trying to kill him? Seen it too many times folks stop being active they go downhill fast. I'm not the only to make that observation.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 9:31am
I'll second that observation.
I get so pissed at my sister and my niece telling my dad he needs to stop doing stuff.  My niece, his granddaughter, literally replies with "what good are you going to do trying to do that?!"  Pretty soon, you here him saying, "I'm not much good anymore."  Breaks my heart.  I try to do things I think he could get hurt at or hinder me unnecessarily quietly by myself...if he offers, I usually let him, or if he says "I could have helped you", I'll say I thought you were busy with something else.  I hate to see him in severe pain as much as the rest of the family.  But have him truly stop doing everything, then see what happens!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2017 at 12:01pm
I ain't gonna quit!! I just have to rest often, can't do any heavy physical labor, Son is a Nurse, won't let me get on a ladder even to change a light bulb. But I try to keep things to do. Who ever said getting old was fun had to be about 30!!!!!!!
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
