WD lifting round bale front weights
Sitesstables View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sitesstables Quote  Post ReplyReply Direct Link To This Post Topic: WD lifting round bale front weights
    Posted: 16 Jun 2010 at 3:38pm
i will be working my WD pretty soon.. I have a narrow front and will lifting round bales with bale spear from the 3-point hitch we out on it,, I can not find wheel weights for it around here in southern Indiana and not sure what else to do besides weld a hanging bracket on front for regular tractor weights.. Or if anyone one has some wheel weights in the Indiana area let me know!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2010 at 5:49pm
Put a loader with a bale spear on the front and separate you hydraulics with a divertor valve so you can use both the loader and lift arms by shifting the valve. Any kind of weight will work and reg suitcase weights are way cheaper than WD stack weights. If you have them on hand building a bracket for suitcase weights would be most economical.
Steve-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2010 at 6:48pm
I have factory original front WD donut wheel weight that go on the front rims.  $200 a pair.  Located in South West Ohio.  45013
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2010 at 7:19pm
Charlie, unless he has power steering , he might be better off picking and moving at the rear of the tractor.  Shouldn't be too hard to lash down some weight over the bolster. Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2010 at 8:09pm
Gary, He might need PS but I was saying you could use the front bale to counterbalance the back one. The problem with that is with a loader the weight might be too far forward. I got it, make smaller bales.LOL
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2010 at 8:36pm
You can fill the front tires with calcium corrode, That will add about #50 per tire to the front end.
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sitesstables Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2010 at 5:49am
When I get some better rims I will fill them with something,, I will just lash down some weight,, We have moved round bales with it before without any problems just wanted a little more weight.. thanks all for posting
cougar766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cougar766 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2010 at 11:31am
if your gonna fill the tires I'd use rim guard (beet juice) will not rust the rims out like calcium will, not harmfull to the ground and tastes a whole lot better if you get sprayed (don't ask), cleans up real easy also
