Wd pulling carb.
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Topic: Wd pulling carb.
    Posted: 20 Jun 2017 at 12:33pm
Been seeming to have troubles with the wd carb on the puller was wondering if a bigger carb would bolt up. This engine is a 240 cube engine at stock rpm (2.5 mph limit is why) I have read there is more than 1 spacing on the manifold bolt holes. Anyhow anyone know of a carb that bolts up
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2017 at 7:38am
what # carb you running?  I would think  a tsx464 would work just fine for 240 cubes.
as far as i know the spacing on wc-d17 all the same, just different bores
Edited by CAL(KS) - 21 Jun 2017 at 7:40am
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2017 at 3:51pm
I use a TSX464 on the mildly built 240 inch engine in my WC. It works great! These carbs are found on WD45s & early D17s. The stock WD air cleaner hose will be too small, but I engineered my own clamp on paper filter arrangement.
Edited by Kip-Utah - 29 Aug 2017 at 3:52pm
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2017 at 4:55am
TSX 464 with a K&N filter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2017 at 7:56am
Ended up with a tsx 464. No junk k and n filter though
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2017 at 7:39am
I have a TSX 848 on mine with a Spectre Filter.
Charlie
