Am I crazy to go magneto?
acisbest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acisbest Quote  Post ReplyReply Direct Link To This Post Topic: Am I crazy to go magneto?
    Posted: 19 Jun 2017 at 8:09pm
Hello,
I have a C, CA, and a WD with distributors. I have a WC with a magneto. I rarely use the C and CA because presently I don't have a good 6 volt battery. I usually end up using the WC because it has a magneto and starts right up with the crank.
I'm tempted to take the money I would pay for batteries and rebuild two of my fm magnetos.
I'm sick of buying batteries for tractors that get little use.
Am I nuts?
Thanks, acisbest
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 8:17pm
Makes sense to me. A good magneto works great for tractors that rarely get used. Have converted a few from distributors for a neighbor and he is pleased with them. As I remember, the cost toi rebuild the mags was less than a new 6V battery.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 9:11pm
Lead acid batteries don't survive well being ignored for long periods. They go bad.
To get much longer battery life get some battery maintainers made for 6 volts and connect them once a month until the battery maintainer signals its completed the charge. That can get 7 to 10 years out of even a garden tractor battery that without that gentle controlled charging might need to be replaced every year.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 9:12pm
I removed a couple distributors and installed good mags... Easy to start with a dead or no battery............. but I also have ONE good battery that I switch between 3 tractors as needed... Get it setup right and only takes 5 minutes.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 5:42am
If your generator is working right, it doesn't take much power to make a spark (on 6 volt) when crank starting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acisbest Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 5:58am
I don't think I can get a spark if I don't have a battery with the delco distributor?
Picked up an old Fairbanks Morse magneto from ebay. I think it's a type 2? It's an older type with a spinning plate instead of a rotor. It had orange paint on it. Are there a lot of magnetos that will interchange with the CA/C/WC or should I be looking for a specific model?
With 6 tractors, two diesel trucks, one vintage car, lawn tractors,  one dozer (24volt) and too many motorcycles to count, batteries become a pain.
My WD does not have the crank installed. I purchased all of the parts but have not got around to it yet. It's twelve volt with and alternator. I can usually find a 12volt battery to pop in it. Someone replaces their battery in the dead of the winter that's still good and I take it.
Acisbest
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 6:24am
You definitely need a battery to get spark with a distributor. What I should have said is that you don't need a very good battery.
The B, C, CA, WC, WD and WF used an FMJ mag. You will also need to change the governor/mag drive to change to a mag.
I, personally would never change from a distributor to a mag. Mags are very expensive to completely rebuild and, basically, a step backward in the evolution of tractors. I can go to the local auto parts store and get new points, condenser, coil, rotor and cap for a distributor for around $60. I just looked in Ebay and found a FMJ rebuild kit (coil, points, rotor, caps and gaskets) for $224.76.
Just my 2 cents...
Edited by WF owner - 20 Jun 2017 at 6:26am
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 6:29am
If your crazy so am I.  At one time we had enough tractors that if I ran one per week each tractor got run 3 times a year. That doesn't keep batteries charged, fresh fuel in the tanks etc. I learned to like magneto equipped, no electrical system tractors. Magnetos have a bad rap they really dont deserve IMO, especially the later ones like the FMJ and FMX.  Once put back in good shape they start and run the tractor at least as good at battery ignition, maybe better. If you cant do the work yourself send it out to Steve at B&B.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 6:34am
OK, I'll go down another road....
Convert the C and CA to 12 volt. Grab a couple CS-130 style alternators from scrapyard for couple of bucks(be sure to get connector ! ).
 Benefits for going 12V include
1) easy boosting from car or truck....
2) better battery recharging using alternator,especially for those 10 minute-1 hr uses.
3) ability to add winches, cheap 12V LED lights, etc.
4) old gennies could be spare for WC ??
5) NO hand cranking...
6) cheaper, no maintenance  12V battery compared to 6V $$$$ ones !
options, just thinking of options....
Jay
alan-nj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 6:51am
Hey Will -- long time since we heard from you...  I'm with you, go with the mags.  And, if you want to save some cranking, get a portable power pack.  Its also cheaper than buying batteries.  Alan
If ignorance is bliss, than happy days are here again.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 6:58am
I do the same as Gerald with the seldom used batts.  also on the lawn tractor and Z turn in the winter.
Use the Deltran models and just leave them plugged in.
Sure is nice to have things crank up in the spring just like you had come back from wally world with a new batt.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 7:20am
Same as Dave and Gerald.  I use the battery maintainers with good success but you will need power where the tractors are parked to use them.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 7:58am
I just found this 6/12 volt smart charger.
It might work well for charging/maintaining 6 volt batteries at a reasonable price.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 9:59am
I'd keep the Distributors and invest in a couple Battery tenders. And I rebuild Mags! Mag parts are getting rediculous in price anymore. Don't get me wrong, a good hot Mag works great, but when they need work, they get expensive to repair.  With the Distributors, you have the advantage to change em' over to electronic ignition which cuts down on tune-ups and messin' with em'. With the Battery Tenders, the Batteries will stay "active" for long periods of time. When you need the Tractor, it'll fire right up. I got 7 years outta the first 6V Battery, 7 years outta the second Battery, and I'm on 4 years now with the third Battery in my B. I don't use the B often, but when I need it, I toss the Battery in, and the ole' girl fires right up! Even in the Winter months. I don't think that's to bad since I restored the Tractor 18 years ago. Just my 2 cents...
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 10:21am
Another valid argument for 12 volt battery replacing a 6 volt battery is that few 6 volt batteries are made and those in the stores have likely sat unattended and not charged on the shelf for half a year or more which does not make them better. It hurts their capacity and quality.
Then with a 6 volt system, there is little tolerance for dirty connections. In my experience (beginning with 6 volt cars in the 1950s) 6 volt battery posts and connectors need to be cleaned twice a year, while 12 volt battery posts probably should be cleaned every couple years but often go a lot longer between cleaning.
Fundamental trouble with the conversion is that its not original. However the SAE standard of vehicular (applicable to tractors too) before about 1960 allowed 6 or 12 volts positive or negative ground, then changed to preferring 12 volts, and by 1970 changed to allowing only 12 volts negative ground. And has remained the same since. 12 volt negative ground surely reduces confusion for neophytes jumping systems or replacing batteries. I think the avoidance of positive ground is because of solid state radios and vehicular controls and displays. Transistors and integrated circuits do not tolerate reversed polarity, they blow faster than fast acting fuses, so in solid state circuits fuses are more an indication of device failure than simple overload.
The voltage regulation of solid state regulators in most common alternators is so more precise it definitely lengthens battery life by being sure the battery is fully charged, but never overcharged. Previous regulator designs didn't hold voltage as well (and were allowed by SAE standards).
Gerald J.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 11:34am
Think it was an Oliver engine I saw the other day that had a coil for each cylinder.How does that work? Lots of small engines have a coil that runs off the flywheel for each cylinder how'd that work on a tractor engine?
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 8:36pm
I have a Leroi air compressor with a Leroi (essentially WD-45) engine and I originally put a battery in it and it has a mag on it.  After the battery failed I quit putting batteries on it and just use the arm-strong starter.  It always starts within 2 or 3 pulls and doesn't crank hard enough to justify the upkeep of a battery.  The unit mainly gets used just in the fall for cleaning combines, and occasionally for sandblasting or running a jackhammer in the summer.
This page was generated in 0.136 seconds.
