injector leak
ALLIS 185 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALLIS 185 Quote  Post ReplyReply Direct Link To This Post Topic: injector leak
    Posted: 16 Jun 2010 at 8:18am
front injector on 185 leaks around injector. isn't the fuel line. Changed seal & swapped injector with new seal to front hole & still leaks in front hole. Any ideas ?
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2010 at 11:45am
Its leaking between the body of the injector and the tip.  Fuel runs up to the top of the  head, looks like a line or bottom seal leaking.  Sometime tighening the hold down scews will stop it, the right way is to take the injector out, take it apart and lap the sealing surfaces on a lapping block. Ive lapped them on a peice of glass before, that seems to work.  Its possible the nut didnt get tightened enough when it was assembled too, if the injector has been in a long time, thats usually not the case.   HTH
