New gears and old gears
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Topic: New gears and old gears
    Posted: 17 Jun 2017 at 4:41pm
Got the wd running, when we removed the engine to overhaul it we also gutted the transmission to fix a wore 2nd gear that was making alot of noise. We ended up using parts from a wc parts tractor since the wd has the straight shifter. So now it has a combo of wc gears with low use and original wd gears that still looked very good. The transmission is now noisy in all the gears except road gear. I am wondering if the gears will quiet down once they develop a wear pattern with reach other. Before all gears but 2nd were quiet
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2017 at 8:00pm
The early WDs (straight shifter) have straight cut gears and they do make noise.
Since you have apparently "mixed" some gears the noise may be a bit more than usual.
I personally don't think you have anything to worry about.
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2017 at 10:47pm
Sounds like you changed the 4th gear input shaft, I have seen this before.
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2017 at 10:51pm
we replaced 2nd gear in our CA and we put a new gear against a old gear now we have a "wine" in 2nd gear, they say it will set it self in time but it does sound bad.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2017 at 12:48am
They are noisy from the beginning.Think you were trying to fix a problem that was just normal.Dad's new WD (now mine)has been noisy always.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2017 at 6:56am
no, they are NOT noisey.....rather just saying " I'm happy to be in the fields again".... hehehe
Heck ANY tractor running and working is a GREAT thing !!!
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2017 at 9:06am
No this second gear was definetly bad. It was pitted and wore on the teeth edge.
Before all others were quiet but not anymore lol
Edited by blue924.9 - 18 Jun 2017 at 9:07am
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
