Roto-baler,bale loader&rake "quiz" pg3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: Roto-baler,bale loader&rake "quiz" pg3
    Posted: 13 Jun 2017 at 10:16pm
Ok I'm a day late. Lost track of the days. Hear we go on pg 3
12.    The new soft center bale attachment will fit:
          ( ) a. 1954 roto-balers only.
          ( ) b. roto-balers from 1950 on, only.
          ( ) c. All roto-balers.
13.    Baling hay that is too wet or improper handling of baler in the field may result. In:
          ( ) a. Bales that are too big.
          ( ) b. Bales with hard center cores.
          ( ) c. Bales with hollow centers.
14.    In using the soft center bale attachment:
          ( ) a. All the hay is wrapped up under less tension than is set on the brake.
          ( ) b. the first hay to enter chamber is loosely wrapped, not under compression.
          ( ) c. The outside two layers are loosely wrapped to allow bale to expand.
15.   In comparing baler prices we find:
          ( ) a. A great number of low-cost, pto operated balers.
          ( ) b. the roto-baler in a price class of its own.
          ( ) c. The roto-baler has a slight price advantage of about $75.
16.    The big market for roto-balers is:
          ( ) a. Selling to the custom operator.
          ( ) b. the family-sized farm, for a man to do his own baling.
          ( ) c. In a few scattered sections of the country.
17.    The a-c bale loader is:
           ( ) a. Tractor-mounted, pto driven.
          ( ) b. a pull-type, pto machine.
          ( ) c. Tractor-mounted, traction driven.
18.    In order to successfully use this loader:
          ( ) a. Bales should first be lined up in the field.
          ( ) b. Bales can be positioned at any angle-bale loader will line them up.
          ( ) c. Driver must hit bales just the right angle.
Enjoy guys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 10:36am
Anybody going to do this one
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 10:46pm
Bump
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 10:54pm
I don't know all of them, but here are what I think are correct.
14. B
15. B
16. B
17. A
18. A or C, but after talking to guys at Hutch who used them back in the day, I'd say C.
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 6:49am
14. C
15. B
16. B
17. A
18. B
This page was generated in 0.142 seconds.
