does your mower belt and pulleys get hot ?
cdon_FL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdon_FL Quote  Post ReplyReply Direct Link To This Post Topic: does your mower belt and pulleys get hot ?
    Posted: 13 Jun 2017 at 9:42am
Just installed L306 under my CA.  First time mowing.... belt and pulleys get hot.  Seems like this is not right.
After using it for a while I cannot put my hand on the big PTO pulley it is so hot.  Belt seems gummy from the heat.
I don't think the belt was slipping on any of the pulleys.  I stalled the tractor a couple of times in high grass on little mounds of dirt.
Is this normal ?
Chris in NE Florida
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2017 at 9:56am
Hard to say.  All the horsepower it takes to mow is being transmitted by the belt.  It flexes, changes direction, grips, torques.....it's going to get hot.  How hot? . . . seems "gummy from the heat" is probably a tad too hot.  Maybe a touch too tight?  Pulleys all in reasonable alignment?  Turn freely?   You're in Florida, how hot was it outside?
Edited by Tbone95 - 13 Jun 2017 at 9:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2017 at 11:24am
Those Woods mowers are Finish mowers, not meant for tall grass.  Trying to cut 6 inches or more of grass with one will cause things to heat up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2017 at 1:30pm
Yeah, what he said.  All that and you stalled it a couple times, sounds like it was being pushed to its max.
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2017 at 1:42pm
Yep! You won't want to put your hand on them after running. :) We have ours adjusted so it slips belt though! Sounds like you got it to tight!
Edited by farmtoybuilder - 13 Jun 2017 at 1:43pm
