Finding TDC D17 Series 1 gas?
Roscoe62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Topic: Finding TDC D17 Series 1 gas?
    Posted: 12 Jun 2017 at 9:10am
Trying to check the valve gap.  I can't see the timing marks due to the front-end loader being in the way.  I could use a mirror, but that required two people, and I did not have any help.
Is TDC always when the distributor rotor button is pointing at #1 spark plug wire?  AND, do I rotate the engine one full turn, until the rotor points at #4 plug wire to get it on the #4 compression stroke, or is it more complicated than this?
As usual, I messed something up.  After adjusting the valves (while hot) to 0.013", #2 and #3 cylinders are not firing at all.  I checked this by removing the spark plug wires one at a time, it runs much rougher when #1 and #4 wires are removed, but no change when either #2 and #3 are removed.
This engine was rebuilt about 100 hours ago, and it is having power problems after it gets hot, so I thought a quick check of the valve lash would be a good thing to rule out.  I followed the instructions in the I&T book where you adjust in and out on #1, and one each of #2 and #3, and then rotate the engine until #4 is on compression and adjust those two, and the alternate ones on #2 and #3.
So, me being me, I must have messed something up and I now have a new opportunity to find the problem.
This has the Petronix electronic ignition, and nearly new plug wires from Steve @ B&B.  I tried swapping the #2 and #3 plugs out with two used ones that were in my parts bin, with no success.  I doubt that is the problem.
Stopping today to get new plugs, but I am am thinking I messed something up when adjusting the valves.  Some were just slightly tight, maybe .008 - .011 instead of the recommended settings.
Anyway, now it is worse than before,
        running on two, instead of four.
Thanks,
- Roscoe
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2017 at 10:49am
Do you have the 2 and 3 plug wires reversed? Since Firing order is 1-2-4-3, if 2 and 3 are reversed, you would only have 1 and 4 firing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2017 at 10:58am
TDC should be when the rotor is pointing at # 1. Turning one full turn should be TDC for cylinder #4. (Compression stroke should be just before TDC)
Power problems when warm could be a few things:
~Spark plugs not gapped right . Do not use Champion plugs. They don't work well in an AC 226 engine
~an obstruction of fuel
~coil getting weak
~poor condenser
Does it have good power when you first start it and loses power after it warms up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2017 at 11:56am
No, I double checked the firing order.  Sounds like I got the TDC thing correct.  I re-checked the valve gap two additional times.
Could be the spark plugs, there were champion J8C's.  I am picking the 295's today.
Could be the coil.  But it means that I have two weak coils, I swapped it out once already.
Could be a fuel or air restriction.  That is where I was heading before ruling out the valve adjustment.  Once I get #2 and #3 firing again, I am going to clean out the air cleaner, and then get the carb rebuilt.
Could also be ignition timing, since it was also getting hot.  I will re-check that with a light and mirror, once (if) I get it firing on 4 cylinders.
It did run good when cold and get worse at it warms up.  But now, it is running on #4 and #1 cylinders only.
It does not have a condenser.  I have the electronic ignition on it.
Thanks.
- Roscoe.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2017 at 8:17pm
I have seen engines run bad from the valves being too tight. They may run fair when cold but get worse as they warm up, even die . Are your rockers or rocker shaft worn bad? They can cause the problem with valve adjustment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2017 at 7:12am
As per DrAllis, "adjust all the valves to .015" COLD".
