D15 lever by starter
iowallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iowallis Quote  Post ReplyReply Direct Link To This Post Topic: D15 lever by starter
    Posted: 11 Jun 2017 at 7:38am
Doing an oil change/fluid checks on my mom's D15 and noticed a lever on the top side of the transmission housing below the starter. Maybe a foot long or a little less with a hole at the end. Moves side to side a little but I didn't move it much because I didn't know what it does. What does this lever control? It isn't hooked to anything.
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2017 at 7:47am
shift lever for the belt pulley
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2017 at 7:51am
The lever is to engage the belt pulley. Most of the D series tractors left the factory with the lever in place just to keep the housing sealed. If a tractor was ordered with the belt pulley option all that was needed is the rod from the lever to the dash and the pulley assy mounted on the side.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote iowallis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2017 at 8:02am
Thanks for the answer. Tractor doesn't have a belt pulley, but looks like there is a block off plate on the side where one would be.
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2017 at 8:42am
yep.
