620 oil levels.
jeff n View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeff n Quote  Post ReplyReply Direct Link To This Post Topic: 620 oil levels.
    Posted: 10 Jun 2017 at 10:10am
Hi I just got a 620 and I don't really know where to check the trans / hydraulic oil. I found a plug on top of the rear end but can't find a drain plug.i put a new hydrolic filter on and would like to change the oil as well. Any info would be helpful thanks .
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2017 at 5:09am
You have to remove the metal cover from the under side of the rig, runs from the engine to the trans/diff.
Then unhook the electric wire from the temp sending unit and remover the temp sending unit, at the front end of the trans/diff.
That is what my books tells me to do to drain it.
Edited by Gary in Texas - 11 Jun 2017 at 5:10am
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2017 at 9:17am
My 720 has a dipstick on the bottom of the square head fill plug on top of the rear end behind the seat.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2017 at 9:55am
616 has street ell turned upright on the right side with petcock that is the high leval           could depend on early or late 620,      still drains in the same place as mentioned above post
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeff n Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2017 at 12:59pm
Ok thanks for the help I'll check it out in a few days. Can you still get any books anywhere for this tractor?
Allis Gal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Gal Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2017 at 8:10pm
This page was generated in 0.058 seconds.
