Allis Chalmers HD9B
Ralph Odegard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ralph Odegard Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers HD9B
    Posted: 08 Jun 2017 at 6:09pm
I am searching for Oil Filter Cartridges for an HD9B. Engine is a 471 Detroit. Machine was built in 1952. Actually I have two HD9B's  with the same standard AC oil filter mounted on the left side of the engine with no numbers or info.  Having trouble finding the right cartridge to fit.  Important:  Measuring the Cartridge Container it appears the cartridge  would measure approx.  1/2"ID x 3 3/4" OD x 7" long.
gemdozer View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 6:41pm
The 471 DETROIT ELEMENT OIL FILTER(full flow PF-132)
==========================(by-pass P 117)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ralph Odegard Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 11:47am
I will check out brand hopefully and size measurement, thank you.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 5:56pm
WEll, make sure you have all the parts inside to hold the filter securely...  I ran across a A JD that somebody forgot to put the spring, seal, plate and snap ring into so there was NO real filtering of the oil... and then I found a McDeering 400 diesel that somebodey didn't bother to put the right filter adapter in... well they didn't bother to put it in, was missing on first filter element so the final filter plugged up. Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ralph Odegard Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2017 at 9:01pm
Still looking for correct oil filter for HD9B. I have two numbers from gem dozer but unable to find brand.  Correction on my post : found a used oil filter and have the correct measurements which are 1/2" ID x 3 11/16" OD x 61/2" long   (please help)
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2017 at 3:59am
A quick look on the googler suggests the brand might be AC Delco
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2017 at 5:44am
Try Application Associates under Baldwin Filters. They have application catalogs for most any machine with access to obsoleted filter by other companies that Baldwin still produces. Is where I buy my filters for my 7G.
https://www.baldwinfiltersrus.com/
Edited by DMiller - 11 Jun 2017 at 5:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2017 at 5:58am
The correct Baldwin is a cross to AC PF132 is a P20-HD 4 7/16" OD 1 1/2" ID 9 1/16" long.
This has been a standard sized Detroit filter for a long time.
Edited by DMiller - 11 Jun 2017 at 5:59am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ralph Odegard Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2017 at 12:18pm
Dmiller, The canister for the cartridge filter is 4 inches inside diameter so of course 4 1/2 inches will not go in . The center pin is 1/2 inches for a sealed fit and the length must be 6- 1/2 inches long, The out side diameter of the cartridge is 3 - 11/16 inches.  Thankyou !
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2017 at 2:07pm
for some reason we could not get the bypass filter for our 6-71 in the Hd15,so we plumbed in a new bypass filter assembly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2017 at 3:42pm
The elementoil filter p-117  DETROIT 5572425
--------------------PF-132 DETROIT 5573014
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2017 at 5:30pm
Chevy Oil Filter Element, P117, 1949-1954 - Eckler's Early ...
Chevy Oil Filter Element, P117, 1949-1954; ... 1949-54 P117 Oil Filter Element $16.99 ea. Add to Wishlist; Description; Applications; Details. Reproduction Of Original;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ralph Odegard Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2017 at 10:38am
I would like to thank everyone trying to find the correct oil filter for my HD9B. NAPA 1005 tech bulletin has all the correct dimensions but Wix makes their oil filters Wix 551005 which is 1/2 inch too short in height and too large in diameter to fit canister.  I will machine two adapters for top and bottom so a John Deere filters will work.
This page was generated in 0.219 seconds.
