Fire mark on flywheel
Craig Reavley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig Reavley Quote  Post ReplyReply Direct Link To This Post Topic: Fire mark on flywheel
    Posted: 15 Jun 2010 at 9:08am
If the FIRE mark is in the center of the round hole on the flywheel on a C does that mean that #1 cylinder is top dead center, or can it be off 180 degrees????For some reason I cant remeber. I guess 40 years old, and 25 projects on my mind is taking its toll.
countryguy828 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote countryguy828 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2010 at 9:13am
#1 would be at TDC but it may be ready to fire on #4, I look at the valves to see if both are closed on #1 or #4 to tell the difference. I am sure someone else will have a better description
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2010 at 9:24am
Fire is NOT top dead center, it is advanced where it fires when running..
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2010 at 9:39am
TDC is top dead center. The fire mark is before top dead center. And you have to either look at the valve train or use the thumb in the number one hole to tell which cylinder is coming up on compression in order to tell if number 1 is getting ready to fire.
