Will my D15II run this?
copyrite1972 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote copyrite1972 Quote  Post ReplyReply Direct Link To This Post Topic: Will my D15II run this?
    Posted: 01 Jun 2017 at 10:42pm
This popped up on CL:
My question: Will my D15 II run it? I think it might be missing a hydraulic ram to adjust the height, but I'm good with what's on it now.
Can anyone tell me anything about it?
Thanks in advance!
D15 Series II
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2017 at 1:58am
Really good cutters,I have one I use right much.The D15 can pull it in normal cutting
situations.With reasonably sharp blades they do a good job and that's a good price on it too.The rachet adjuster on it now sets the height,a cylinder just raises it to transport it I usually don't worry about having a cylinder on mine.I rode a lot of miles growing up on a WD45 and one of those hooked  to it,found mine at an auction awhile back.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2017 at 5:05am
I have a 6' cutter on my D-15 II that is used for road ditches. Lots of power.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2017 at 5:13am
I am pulling a 6' BushHog 306 with my D-15II  and it handles it like a boss. Can run in 3rd high unless the grass is knee high.   If you need a cylinder be sure to get some depth stops for it as you will need them due to the iffy hydraulic hold on the 15. I just run the turnbuckle on mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2017 at 6:47am
Don't need the collars on the cylinder with the set up shown the rachet assembly
holds it to whatever cutting height needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2017 at 7:02am
Ohh, OK I looked at the pictures and see that. On my Bush hog the ratchet replaces the cylinder, no place for both.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2017 at 10:37am
That one hasn't been used too hard....the sides still look flat. Worth the money.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2017 at 1:07pm
If your Series Two is in  reasonably good shape engine wise, it will have no issues with it.
My "tired" high hour SII SC runs a heavy 6' Bush Hog brand cutter with a A-C 3-pt. adaptor.
1st gear low or high range on the PD, in brush/native grasses sometimes above the radiator cap.
2nd low range all day long in open pastures, 2-3' tall grasses including bunch grasses.
Keep it up so only cutting 3" minimum height and just touch a grinder to the blade edges occasionally and she will be fine. I have the 5" version (3-pt.) of that cutter and the clutch set-up is sweet. Just be sure to check the two pins/springs on the clutch assembly before you put it to work and check the tension nut.
Kept lubed, they are tough old units.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2017 at 1:42pm
Great mower. Only thing to watch for is when turning. Don't turn too sharp. The tongue is the weak link on them.HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote copyrite1972 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2017 at 3:57pm
Thanks for all the input Fellas! Think I'll call him (After I talk to "The Boss" about it! LOL)
D15 Series II
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2017 at 10:45pm
It's no longer listed, hope you were the buyer!
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote copyrite1972 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2017 at 11:53pm
Cry Nope, called 10 minutes too late......
Thanks Fellers! maybe next time
D15 Series II
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2017 at 7:04am
The buyer probably didn't have to ask his wifeCool
Post Options Post Options   Thanks (0) Thanks(0)   Quote copyrite1972 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2017 at 11:21pm
Ouch! Clap
D15 Series II
