Off Color (ish) - Aftermarket Hydraulic Pumps |
Post Reply ![]() |
Hurst ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Midway, Ky Points: 1218 |
![]() ![]() ![]() ![]() ![]() Posted: 26 May 2017 at 8:30am |
Off color in the sense I'm working on my Ford 6610. But what is the consensus of the "economy" no-name aftermarket hydraulic pumps on the market today? I am looking at a new pump for my 6610 because it stripped the shaft and splined hub inside the main body gear where it goes to drive the low pressure section of the pump for the PTO and Dual Power circuit. The parts to fix it are $350-$400 range, and the aftermarket replacements can be had for as low as $230. I know they are likely throw-away pumps in that they won't use the OEM seals and gears, but for the diffrence (a reman from NH or a new Dynamatic OEM pump are $6-800), if the reliability is decent on these pumps, I feel it might be worth the risk, especially when money is tight on the repair budget.
Hurst
1979 Allis Chalmers 7000
5800 Hours |
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
A good source of pumps is Baum Hydraulics. http://www.baumhydraulics.com
Their on line downloadable catalog searches better than their website but shows resale prices, they give a discount for direct purchases, typically coded as DATE 2000 on each page, sometimes different values down the page, 2000 means 20% discount. Gerald J. |
Thank you for the link! I'll look into it.
Hurst
5800 Hours |
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
I picked up a brand X 2 stage one on the net for $125, we used it on a log splitter we were building. Running it with a big honda engine. works great.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 53976 |
Here's another good source:
Post Reply ![]() |
