Allis offset grind with flat head rods???
Unstylish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unstylish Quote  Post ReplyReply Direct Link To This Post Topic: Allis offset grind with flat head rods???
    Posted: 14 Jun 2010 at 11:20am
Anyone ever use Chrysler or continental flathead 6 rods in an offset grind? I have some here that are about 7.75 long and have about 1 15/16. Journal. That's only 1/16 smaller than a buda and is just a little lighter duty.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2010 at 12:00pm
Andy I am trying to deal with a fellow friend on tooling up to make some aluminum rods with the 1.880 journal in a couple of different lengths. A fellow could pick up .495 stroke without welding and be standard on the bearing. go 20 under and get the half inch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unstylish Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2010 at 6:35am
Yeah, I had an old Sharps motor, 360 cubes 9 to 1 with aluminum rods with a 1.75 journal. It lasted 7 years till MY, MY, MY mistake took out the crank. But it was a lugger. Still, 1.88 journal is a little small to my taste. I'd like to stay around 2 inches. I'd like to find a set of aluminum rods to make an offset combo out of, but unless they around around $4-500 (which I can't see how they will be) I personally can afford it, and will have to stick to (free) chrysler rods. Of course, they wont have the strengeth the aluminum ones will have either..
