AC 620 front timing marks?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: AC 620 front timing marks?
    Posted: 20 May 2017 at 6:34pm
I have a 616 that has a 620 engine in it. On the front of engine, there is a indicator that has a mark to set to mark on front clutch. The Simplicity manual shows these on the 4041 .It doesn't clarify where to align the marks up at timing. I know it should be 20 degrees before TDC using rear engine marks. I don' want to use them because of all the stuff you have to remove. Any help appreciated. Thanks tracy
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 9:13pm
dont you time that there the timing hole on the blower houseing
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 8:24am
Tracy, I just timed mine by ear.  starts right now and seems to be fuel efficient.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 8:41am
There is a set of marks on the front of the 19.5 Onan. I got the info to align the marks from the Simplicity guys on facebook. Mine seems to have valve chatter in a hard pull uphill. Not sure if it is timing or valves need adjusting.  Tracy
