Roto Baler
drak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drak Quote  Post ReplyReply Direct Link To This Post Topic: Roto Baler
    Posted: 18 May 2017 at 2:41pm
Can anyone give me the measurements and weight of a Toto Bailer ?
I need to travel 300 miles to collect one but first need to hire a suitable truck or trailer to carry it !!
Randy MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 3:12pm
Width for field work - 9' 10"
Width for transport - 8' 10"
Swinging tongue adjustment - 33"
Overall length - 13' 6"
Overall Height - 6' 11"
Shipping weight - 2,300 lbs.
34 WC #477, 38 B #1935, 1-116 on steel, #8 7ft dbl action disc, #9 5ft dbl action disc, 295 Chainsaw
drak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drak Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 3:26pm
Many thanks Randy
Thats very helpful, now I understand exactly what I am dealing with
Much appreciate
John
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 5:38pm
I've never done it, but supposedly there is a way to break them down into 3 pieces very easily for hauling. Years ago, someone posted about that, and said that it was very easy to do, and had a picture of it. Darrel
BobPaulusCentrOH View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobPaulusCentrOH Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 9:03pm
The feed table comes off pretty easily.  Back the bale chamber section on a trailer.
Take the tongue and PTO off, and lay it on trailer lengthwise.
Take feeder table and stand up next to bale chamber.  Strap everything down and you can probably get everything on a bumper pull 16 ft. x 7-1/2 ft. trailer.
Good Luck.  I once upon a time dragged a white top 70 miles or so, but not 300.
Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 10:08pm
Here is a link to an old post. Dave Richards has a pic of one he hauled in pieces.
http://www.allischalmers.com/forum/transporting-a-roto-baler_topic93978.html
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2017 at 6:16am
  That is a useful picture.  Thanks to CTucker for resurrecting it.  Recently I have had some requests for the original slide show.  Try this link.
http://public.fotki.com/dave994/roto-baler/roto-baler.html
Edited by Dave Richards (WV) - 19 May 2017 at 6:18am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2017 at 10:45am
Dave, this should be saved in the Knowledge forum. Pretty good step by step with good pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2017 at 6:34pm
If you have a low slung car trailer, you can crib up one wheel, and lash it down real good, it will fit through the GW bridge toll gates, if you get them to hinge in the safety shields for the toll takers...WinkWink
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2017 at 8:31pm
Tow it home, I towed a Roto Baler to my home from Raleigh NC nearly 200 miles and it had the Aux engine on it.One flat was all the trouble I had, just get a hitch to center it behind your truck.
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2017 at 4:05am
Friend and I hauled this one from East Iowa to S.W. Oklahoma.
Gary in Texas
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2017 at 6:44am
Gary has the right idea. Lift it up with two loaders or a crane and set it down on a trailer and take the wheels off. Also the stub axles will easily come out with just one bolt, removing the right one will allow it to be under 8'.
   I have made a set of small wheels that clamp under the twine box to allow it to be loaded on a deckover trailer with ramps, no dis-assembly required.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2017 at 12:40pm
I took my CA and backed one on a guys trailer and he hauled it from north east Ohio to West Virginia. Just flagged the over hang
drak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drak Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2017 at 2:58am
Many thanks to all who has given their advice and suggestions, its all been very helpful and I now know exactly what I need to do, Clap
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 8:44am
Just throwing this out there.  I see you are in the UK.  Some of the Roto balers in the UK had special axle arrangements to make them narrower for transport.  You might want to see if this baler is a narrow one.  Might help in your transporting.
Jim
This page was generated in 0.555 seconds.
