2 bottom Disc plow question
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Topic: 2 bottom Disc plow question
    Posted: 15 May 2017 at 3:37pm
I want to mount a 2 bottom Disc plow I have to a WD pin hitch tractor.
I would by a manual if any has one also.
one of the question I have,
The Disc low I have bolts to the drawbar.
does it require the support that holds the drawbar to be removed?
Any help appreciated.
Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 6:14pm
Bolts to the snap coupler drawbar, and yes, you do remove the bail, otherwise it wouldn't lift/lower...
Make sure the tailwheel ain't worn out, or it will pull side to side, all over the place. A new coulter, will replace the tail wheel cutting edge, nicely...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 7:40pm
That what I thought on the drawbar,just wanted to make sure.
Also appears that it had higher bracket not for were it bolts up to.
