8030 muffler delete
thumbfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thumbfarmer Quote  Post ReplyReply Direct Link To This Post Topic: 8030 muffler delete
    Posted: 12 May 2017 at 7:26am
Hey I'm new to forum, and have a question about a muffler delete on an 8030. Anyone try it? Any hp gain? Engine run cooler? How much louder is it? Thanks!
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2017 at 8:16am
Huh?!
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2017 at 8:23am
IM sure he's thinking chrome straight pipe
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2017 at 8:32am
Thomure     800  527 9954 sells muffler eliminator exhaust kits - with aspirator tubes.
There is almost no restriction in the OEM muffler at field settings - you will not see any measurable difference - you will hear the engine respond w/o the muffler - have a customer using one - it is not like a straight pipe , but louder than oem muffler.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2017 at 9:45am
I have the Thomure eliminator in an 8050, performance no difference. Inside the cab it sounds no different than the factory muffler but from the outside it sounds louder and really bellows with factory pipe though the hood. I'll put it on the other 8050 & 8070 when those mufflers rot out.
Leon B
mark-east-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark-east-tn Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2017 at 9:31pm
What do those kits cost ? Ive got a 8010 Ive thought about doing muffler delete .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 7:08am
8010 is probably different from the 8030, 301-426. Call the number above, asking is free.
Leon B
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 7:50am
what leon said is exactly correct I belive it does eliminate some heat under the hoood . when you price a new muffler like most of us you will be calling for an eliminator once you pick yorself up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 10:49am
Getting ready to eliminate the muffler on my 7020 for more visibility. I found a 4" x 12" resonator that will fit under the hood and plan to run a 3.5" pipe from there up, lining it up with the pre-cleaner pipe. I'm hoping it wont increase the noise if I get it above the cab.
Leon B
Edited by Leon B MO - 13 May 2017 at 10:50am
