powermax rototiller pto shaft question
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Topic: powermax rototiller pto shaft question
    Posted: 11 May 2017 at 2:10pm
should the pto for a 616/620/720 rototiller be able to pull in half?  Mine is stuck hard (not the shield) and I'm running out of ideas to get it free.
ac720nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2017 at 5:32am
It may sound strange but I had one I couldn't get apart and soaked it good then I chained one end to my dually and other to my Silverado and pulled them apart , it worked for me. May not be everyones cup of tea.
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2017 at 5:37am
I chained mine to the ton cylinder on my cherry picker and kept snapping the bolts holding the chain
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2017 at 12:59pm
Wow! can't say I've ever heard of one that tight till now . Be careful or you'll bend it
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2017 at 8:51pm
I put my brush hog pto between to metal support posts in my garage. Strapped one end to one post and a come along to the other utilizing 5,000lb soft straps. Tightened it up. I had been greasing and using Kroil on it for 2 days. I let it set over night. The next day I took a map gas torch and heated the stuck area. Within 10 minutes one click at a time it came apart without damage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 6:20am
How are you guys holding on with the straps?  Through theknuckle of the u joint?
Bird76Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bird76Mojo Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 8:22pm
Be sure to apply a good grease, with added anti-seize, liberally to the inside of the slip yoke after you get it apart.
GB :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 7:19am
well i got it apart.  hard to tie 1 end to a railed tie fence post with a cable clevice and the other to the skid loader in the same fashion.  Came with a pop but its wierd, the shaft is rust free and greased.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 8:28pm
Is it bent a little ? doesn't take much
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 8:47am
I'm wondering if you are right on it being slightly bent.  I will not slide together fully after pulling it apart
