New to tractors; CA questions
bramdad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bramdad Quote  Post ReplyReply Direct Link To This Post Topic: New to tractors; CA questions
    Posted: 11 May 2017 at 7:47am
Hello everyone
I'm brand new to tractors, but I recently bought some acreage and will be needing a small tractor for various chores around the property (brush hog, driveway maint, pulling logs, etc).  I've found an A/C CA for a reasonable price and from what I've researched (mostly through this forum) it should handle any tasks I throw at it.  My questions are as follows:
1)  The owner said the hydraulics aren't working, but he doesn't use it as he just pulls haying equipment with the tractor.  He said it might be the points?  Worst case I have to replace the system...how big of a deal would that be; I have general mechanical skills/knowledge?  Also, what implements would require the hydraulics (again, I'm new).
2)  The CA has the snap coupler...how difficult is it to find implements that will work with this tractor (blade, brush hog, maybe a dirt scoop someday)
Thanks for sharing your knowledge
Ray
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 7:54am
Does the owner realize the PTO has to be engaged for the hydraulics to work?And its not the points that keep the hydraulics from working.
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 10:07am
as far as the snap coupler, it can be converted to 3pt hitch if needed. but I see plows and such for the snap couplers for sale regularly. most equipment don't require a hydro hook up.  just a way to lift them if they aren't ground driven.  there are a lot of brush hogs for sale out there that have wheels on them so ya don't need a 3pt hitch, back blades not so much, most I see are 3pt hitch.
Edited by dt1050 - 11 May 2017 at 10:10am
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 10:28am
If the lift will not work with the pto engaged, you may want to think twice about buying the tractor.  The hydraulic pumps are a pain to work on if you do not have some experience with them.   Also it is a good idea to check the transmission oil.  The dip stick is on the left side at the final drive.  If the oil is milky, it would indicate that water is in the oil which can clog up the pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 11:54am
The CA hydraulic pump is very easy and simple to work on. If the pump doesn't work at all with the PTO engaged and full of oil, it probably needs new springs under the plungers. The plungers are pushed by a cam on the PTO shaft but rely on a spring underneath the plunger to push it back out to draw in the oil.
Edited by Brian Jasper co. Ia - 11 May 2017 at 11:55am
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 11:59am
One of my CA's hydraulics wouldn't work once and I took the pump off and the pickup tube was clogged with 3 small globs of silicone gasket sealer.Angry
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 12:24pm
You'll definitely need the hydraulics to do what you described. You also might want to consider converting it to a 3 pt set-up. You'll likely be able to find a blade that will fit the snap coupler; but brush hogging, mowing, etc you'll be confined to pull behind mowers. The snap coupler dirt scoops are seen from time to time. A lot more options with a 3 pt set-up
Points have nothing to do with hydraulics. Good luck.
D17 Series 1
Allis B- 1939
Allis B- 1945
Post Options Post Options   Thanks (0) Thanks(0)   Quote bramdad Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 12:33pm
Thanks for all the responses.  I'll take a look at the tractor soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 1:46pm
...and you might want to consider posting the asking price of the tractor and condition. A lot on here can give you feedback in terms of underpiced/ overpriced
D17 Series 1
Allis B- 1939
Allis B- 1945
Post Options Post Options   Thanks (0) Thanks(0)   Quote bramdad Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 1:51pm
Asking is 1800. New tires. Current owner has used it for 4 years for haying and general use. All pics show good body and paint
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 2:06pm
$1800 is on the high side for a CA. For that price, it should be in excellent condition with everything working.
BenGiBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 2:14pm
You could post some pictures on here also, and many would be happy to tell you what they see wrong/right, etc.
'39 Model B
Tractors are cheaper than girls, remember that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bramdad Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 2:37pm
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 3:34pm
Looks like a decent CA for 1800. A good CA is a great tractor that will work all day on 5 gallons of fuel. Remember to turn on the pto to check the hydraulics (the lever thru the floor pan under the seat on the left side). You can purchase a 3 point adaptor from several of the vendors on this site; great folks who will help you out. I have welded ears to the rockshaft for the top link; Just be sure they are up fully when attaching them so they don't hit the seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 3:51pm
The hand clutch lever is missing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 5:03pm
It looks like a nice CA( yeah, I had one,sniff..) but I don't like the spray paint on the distributor cap,wires and rad. If she starts and runs good ,1800 is kinda high. I'd try $1300, secure seal at say $1500.as no working hydraulics.
Rebuilding the pump is easy, just have a CLEAN, well lit workbench ! I spent couple hours looking for one of them itty bitty check balls( ball bearing) that kind fell onto my concrete floor. I do remember needing to clean a 4th ball int he 'front' side of the pump, after that,she worked like new. Cleaning out 50 years of sludge from the sump probably helped too !!
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 9:04pm
As noted, it's missing the hand clutch lever. Likely means that the hand clutch is inoperative - which means that you can't stop the tractor's motion without pushing in the foot clutch and thus also stopping the pto. Which could be an issue if you are brush hogging with it. Would not be an $1800 tractor for me - maybe half that? But value is in the eye of the buyer. LOL
WC, CA, D14, WD45
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 9:44pm
Looking around at his other equipment he doesn't spend a lot of money on maintenance but the little tractor could still be basically sound. Oil pressure good, no rattles or knocks,no smoke at start up, doesn't jump out of any gears, steering is tight, brakes good. Just look at as if you were buying and old car for your daughter to drive to school. I did notice the broken lug bolt on the left front, no headlights, and the shutters are  missing if originally equipment, both lift latches are missing their springs and the top half is gone on the RH one. Go to an Allis swap meet. The guys there will surprise with what they have. At the meet at Booneville I saw several pumps there for the CA. The condition of rear tires are a big plus. But agree with the others the price is quit a bit too high and if he won't move very much, leave your name and # and move on. There are others out there. They truly are an amazing little tractor. At their size there are none better.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 10:16pm
Looks good in the pictures. A little grim on the engine is good means it's wasn't pressure cleaned just for sale. Has new tires. A $1300 CA wil need $ 1500 in tires to be a good tractor. The hyd pump is very easy to work on and has very little to go wrong. Drain the rear pull 4 bolts an a couple cotter pins and take it to your bench. The hand clutch missing isn't a big loss for me. I rarely use mine and think it was a bad design .three point ad peters are easy to come by but anything heavy will make the front uncomfortably light. My CA only sees morning duty. At one time it did every thing except mow. I still have the loader mounts installed they make a great step for climbing on and off. But the last time the loader was installed was several years ago. I needed two loaders to lift a 16' selfpropelled swather sideways on to my trailer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2017 at 12:22pm
$1800 isn't out of line for a nice CA. There's nearly $1K in new tires on that one. Those definitely are not 11.2's. Looks like 13.6's as tall as they are.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2017 at 2:54pm
I like my CA a lot that being said if I were in your position I don't think I'd be buying that CA.Its got some problems and $1800 is at the  top of a CA value as far as I'm concerned.Then add the cost of a 3pt adapter that will never work with most 3 pt equipment
as good a tractor made to have 3pt you'll be close to $2500.Lots of good 3 pt hitch tractors around for that kind of money that'll be more suitable for what you need than a CA.Of course you have to spend the $$$$ so you need to decide for yourself.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2017 at 3:23pm
If it was mine I wouldn't let it go for less that 2500.00. I am old enough that I learned to run a tractor without live power take off and without an over run clutch. The CA's I owned were somewhat weak in the hand clutch anyway. If it has been done away with on this tractor it would be a plus for me. It would save me from putting in a solid axle.
