1981 Allis 6080 surging issues |
Post Reply |
Steve16
Bronze Level Joined: 07 May 2017 Location: Kansas Points: 2 |
Posted: 07 May 2017 at 9:52pm |
I have a 6080 that will run anywhere from 10 minutes to 30 minutes and will then start to surge. It will surge two or three times and then will die. It will not restart for 12 - 24 hours and then we repeat the cycle. I have changed fuel filter - bled lines - changes fuel lines. Any suggestions?
wekracer
Orange Level Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1587 |
Sounds like something in the fuel tank. I just had a similar issue with a 175. I siphoned out the tank and put a piece of 1" hose on the end of the shop vac and sucked the tank out good. It's been fine since but I haven't run it much. Good luck
victoryallis
Orange Level Joined: 15 Apr 2010 Location: Ludington mi Points: 2876 |
Agree Unless it has a cab not hard at all to pull the tank and clean it. |
Lynn Marshall
Orange Level Access Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2257 |
The shut off tee in the bottom of the tank is known to be easily restricted. Check for a strong flow at the tee.
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4863 |
flex ring breaking down in pump, and the pieces are plugging the return fitting in the top of the pump. Take it out, see if it's plugged, and clean it out and it will buy you some time until you can get the pump rebuilt.
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8165 |
Following ED,loosen screws holding timing window to relieve pressure and see if it starts right up.If that works,be time for rebuild.
Post Reply | |
