Power shift wheels |
Post Reply |
littlemarv
Orange Level Joined: 10 Jun 2013 Location: Wisconsin Points: 1829 |
Posted: 06 May 2017 at 11:18pm |
On the wheels on my WD, there is one stop on one rail each. How many are there supposed to be?
It looks like there are several holes in the two opposing rails. The reason I ask is because today, while plowing, the left wheel shifted all the way out on its own. The one stop was on the wrong side, so the wheel was able to shift all the way out. I shifted the wheel back in, and moved the stop to the other side of the eccentric bracket. I would think there should be two stops per wheel? Are the eccentrics supposed to hold the wheels on their own, or are the stops the primary holding device? Some stuff you never really look into, until there is a problem... Thanks in advance. |
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
DennisA (IL)
Orange Level Joined: 11 Sep 2009 Location: Ridott IL. Points: 2064 |
2 stops per wheel and the eccentrics are not made to keep the wheels from spinning inn or out. They just keep the wheel centers tight with the rims.
Thanks & God Bless
Dennis |
dt1050
Orange Level Joined: 05 Jul 2011 Location: central pa Points: 1078 |
x2. my d14 has one stop on the right side and 2 on the left? I have a couple of rusted out rims, hopefully there's another good stop on one of them..lol. my 1 wheel was adjusted all the way in, the other all the way out. took a lot of heat and a 4ft bar to get the bolts loose!!! maybe the rust is supposed to keep them in place!! edit, after looking at the photo again I see the problem, your wheel is to nice and shiny, poor some calcuim on it and let it set outside fer awhile, that rim will never move again. oh, that's a joke. need some pics of the rest of the machine.. Edited by dt1050 - 07 May 2017 at 4:39am |
DiyDave
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 51374 |
Really only needs 2 on the left wheel, as the tires are directionally oriented, you never get enough push, to move the right wheel, when in reverse, unless the clamps are loose...
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8163 |
I use 2 per....when all in or out the extra goes in toolbox.Could get by with one if on the load side of rail but in tough times doing other things you will slip that wheel without the second stop.
dt1050
I have the wheels all the way out, but put the extra retainer in the next open slot, (toolbox bottom is rusted out). this way I know were it is.lol
Ted J
Orange Level Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18786 |
wiplowboy
Silver Level Joined: 29 Nov 2012 Location: Custer Wisc. Points: 313 |
I think I may have some extra ones. If you want two more let me know. Talked to Merle this evening also. Have a good evening. |
Ed (Ont)
Orange Level Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1257 |
Some of the replacement wheels will only take one unless you redrill the rail. I am in that situation now with titan wheels. 2 were on each side from factory.
Post Reply | |
