720 A.C. will not steer,
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 720 A.C. will not steer,
    Posted: 06 May 2017 at 3:38pm
Getting my 720 ready for garden work after setting all winter, and it will not steer, can't get no reaction at all to the front steer tires,, I drove it around in circles thinking it may come out of it, nope, any recommendations?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 5:10pm
I am assuming the steering wheel turns? Never heard of that issue. There is a bolt that holds the steering wheel on, several roll pins that attach the universal joints to the steering colunm and to the steering box I believe. Check each of them to make sure one hasn't sheered.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 6:33pm
No , the steer wheel does not turn, took the linkage away from the front end and it turns, acts like it should,, the steering gearbox seems stuck,,
Edited by DougG - 06 May 2017 at 6:37pm
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 7:38pm
it was working fine when you put it away?
any chance water got in your gearbox somehow froze causing something to break?
i remember that mine at one time had a spot in the gearbox where it would bind while i was mowing the lawn, u-joints were o.k. just lubed the gearbox inside and adjusted the free play.
if you had a bad u-joint i would think the wheel would turn ever so slightly back -in forth.
might be something in the gearbox or steering shaft.
dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2017 at 10:50am
Thanks for the responses and ideas, went out there this morning beat on the tie rod a little, took a wrench to the place where the tie rod hooks to the gearbox worked it a little and now it works,, don't kno what was hanging up but she's fine now,, whew, it's always something
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2017 at 3:16pm
Glad you got it figured out! Jut got off my 720 mowing with the sickle bar mower. It did a good job although I couldn't lift it correctly until I get a right side cable made up.
