1400 chiselvator
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Topic: 1400 chiselvator
    Posted: 04 May 2017 at 11:35am
Anyone running a small 1400?  I saw a 21 footer for sale and was curious how much horsepower they take to pull.  I was also wondering if they could work cornstalks down good enough to replace a disk.
Thanks!
Life is simpler when you plow around the stump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 11:41am
Model 1400's were available with 7 1/2" spacing or 9" spacing. Be sure to know what you are buying.
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 1:04pm
I think the stalks would have to be good and dry to run a 1400. I can run stalks with my DMI field cultivator but the have to be dry and brittle in the spring. I am sure it won't work in the fall.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 8:52pm
I have a 24.5' 1400 with 7.5" spacing and 6" sweeps. I plow my corn stocks in the fall and cultivate in the spring with no problems. Pull it with a warmed up 220 with 20.8 radial duals and dry ballasted to 17,300 lbs  or JD 7820 mfd
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 1:59am
that's what I did too Calvin.
Dan (SE MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan (SE MI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 11:59am
We have a 28' with 7.5" spacing that works good behind the 7580. It does a decent job on bean stubble. I don't think it would like unplowed cornstalks, but we have never tried that.
Edited by Dan (SE MI) - 13 Jun 2017 at 12:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 9:24pm
Have any pictures
Post Options Post Options   Thanks (1) Thanks(1)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 2:23pm
