Forks for loader,,??
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: Forks for loader,,??
    Posted: 03 May 2017 at 5:25am
   I've recently had several instances where I could have used some forks on the loader of my D14, and would up having to use chains etc, etc to get the job done. I would like to see some examples of what others have built on the bucket when the forks are needed.
 Thanks for any comments, pics.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 6:08am
Joe,,,take a look see at Northern Tool.
www.northerntool/clamp-on-forks
They have clamp on; goes on bottom of bucket.
A friend has them for his loader, they're not for real heavy loading but will handle rated load and usual front end capacity of tractor.
Edited by JoeO(CMO) - 03 May 2017 at 6:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 6:18am
I 'cheated', dropped the 6' wide bucket(4 pins), and built a 'carrier' from angle iron that the forklift forks slide onto. Ideally a 'quikattach'(skidsteer) type system would be best though.
One big concern about forks on a bucket is they're a long ways ahead of the pivot point and you can't see ! Also weight and control issues(real touchy). I didn't get the mounting holes for the tile cylinders right, have LOTS of back, very little forward tilt( curl ?). Since I don't use that D14 often it's not a harship to pop 4 pins to convert but..I ain't getting any younger the older I get, so I might make a Q-A system in the future. When (IF) it stops raining here I'll snap a few pics, send them to you for ideas....
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 10:34am
any of them you mount on the loader bucket, are hard on the bucket.
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 10:48am
I have some clamp on. They are for light duty, made from tubing. If I had to do it again I would have something made to use the bucket mounts because as stated above, the bucket prevents you from seeing what your doing.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
marion View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marion Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2017 at 9:14pm
now you have justification for allis forklift, problem solved
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 6:49am
    Well, Marion,,,,seein as how ole Shameless is always callin me cheap,,,,,,Wink,,,I'ma "might" gonna start lookin for a rebuilder forklift (a cheap one or a gimme),,,but shoot the times I've really needed a forklift are few and far between and too dang much work to remove the bucket off the D14 for some forks,,,,,,,,??,,,maybe I'll just weld some 2" pipe on the bucket and mash em down with my 16# sledge,,,,no need on gettin too dang fancy,,Ya know,,,???Clap
