1937 AC WC Compression Normal Reading
wembry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wembry Quote  Post ReplyReply Direct Link To This Post Topic: 1937 AC WC Compression Normal Reading
    Posted: 13 Jun 2010 at 8:43am
What is the normal reading?
Thanks in advance,
Wayne Embry
Kraig (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kraig (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2010 at 9:50am
If it's the same as a WD, it would be about 110 psi. My WD cylinders are all about 100 psi.
Kraig
7010,D17D,WD45,WD,WC,WC,B,
Gleaner K,60,66,72
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2010 at 11:42am
According to my WC shop service manual:
(Which you can get here: http://www.3000toys.com/allis/manuals.asp)
Gasoline engine - 95 lbs.
Low octane fuel engine - 75 lbs.
Aluminum Piston 217311 - 104 lbs.
The important thing I have heard and read is to have a consistent amount in all 4 cylinders.  If one is way different, then you have other issues.
Hope this helps, let us know how you make out.
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
This page was generated in 0.043 seconds.
